kamhawk
1975 Scotty Serro
Post by kamhawk on Jun 28, 2017 7:52:18 GMT -8
Does anyone see a problem with adding a piece of 1/4" plywood on top of the ceiling panel and then laying the Styrofoam insulation on top of that to create a slope if you will away from the ceiling vent. My thoughts are that it will create a smooth transition for the metal. I have included photos to maybe help with my description. IMG_20170627_200010339 by KamHawk, on Flickr IMG_20170627_200029190 by KamHawk, on Flickr
RinTin
Post by RinTin on Jun 28, 2017 10:36:02 GMT -8
I can't think of a reason why you shouldn't if you want to.
Post by turbodaddy on Jun 28, 2017 18:38:24 GMT -8
Sure, just another way to do it, just not sure 1/4" is enough.
Post by nccamper on Jun 28, 2017 19:08:28 GMT -8
I agree with turbodaddy, 1/4" is not enough. 1/2"-3/4" worked well for me. I wonder if foam insulation will compress over time?
Post by vikx on Jun 28, 2017 21:06:27 GMT -8
Also, if the ceiling panel is 1/8, it won't support the weight of the roof and/or lift much. I would shim at the top and taper the edges to make a smooth transition for the roof metal. 3/4 is great if you can get it.
Post by danrhodes on Jun 29, 2017 5:33:46 GMT -8
vikx is that poplar for the roof framing? My biggest regret is using cheap wood there.
Post by kirkadie on Jun 29, 2017 5:37:59 GMT -8
If the vent is sealed properly, the wood you used will be fine. It's only serving as a shim. If the vent DOES leak, any wood will rot. No worries.
kamhawk
1975 Scotty Serro
Post by kamhawk on Jun 29, 2017 6:27:26 GMT -8
What you can't see is that the cabinets under are 1/2" taller at the front edge than they are at the wall creating a 1/2" rise (arch) in the middle of the camper. Then I added the 1/4" birch ceiling panel, then the 3/4" rafter, then the 1/4" around the vent opening. In theory, that should give it 3/4" rise (arch) in the middle......Hope that explains it better. Thanks for all the response. Next question: Does anyone paint (with asphalt paint) around the vent opening?
Post by nccamper on Jun 29, 2017 7:05:53 GMT -8
I agree with Kirkadie, keeping the water out is the only defense against rot. Even if the roof framing was sealed the birch inside would rot.
Post by vikx on Jun 29, 2017 10:34:17 GMT -8
I believe the photo above is the Hanson; the rafters were poplar. The shim was just pine, something I had laying around...
