charliemyers
Post by charliemyers on Jun 9, 2017 9:01:23 GMT -8
I bought a 30 amp self resetting breaker to put in the 12V side between the battery and the 12V distribution fuse box. One of the studs on the breaker is brass colored, while the other is silver. Does it matter which side connects to the battery and which goes to the fuse panel? The breaker arrived with zero instructions.
Thanks! Charlie
charliemyers
Post by charliemyers on Jun 9, 2017 17:29:38 GMT -8
For anyone else that might be wondering, apparently the copper terminal connects to the battery (or "source") side, and the load connects to the other terminal.
Charlie
Post by vikx on Jun 9, 2017 21:06:02 GMT -8
Almost all breakers I've had are labeled BATT or AUX. The letters are hard to see but they're there...
charliemyers
Post by charliemyers on Jun 11, 2017 17:34:29 GMT -8
Yep, now that I look at it closer, one terminal is marked "Bat" and the other is marked "AUX" just as you say. Thanks!
