cree62
Post by cree62 on Apr 3, 2017 17:53:35 GMT -8
Just want to make sure I am thinking correctly here; advice is welcome! I purchased VCT tile to install in our camper. The current flooring is the original and I believe it is asbestos. This is the reason we are installing a new floor over the top- to enclose the asbestos. Because of that, I don't feel comfortable removing the floor. I'm assuming I can use the tile adhesive directly over the top of the old tiles correct? Also, 95% of the original floor is in great condition, but the other 5% is peeling. I'm planning on (gently) removing these and probably laying new tile in it's place to level it in comparison to the old flooring. Does this make sense? Again, advice is welcome!
Post by nccamper on Apr 3, 2017 18:13:33 GMT -8
Most of us cover the old flooring with luan floor underlayment stapled down over the old tile. I've heard of people sanding the gloss off the old tile but I sure wouldn't do it with asbestos.
Trying to perfectly level out the old floor (old tiles mixed with new) without underlayment may be tougher than you think.
Post by Hamlet on Apr 4, 2017 19:30:17 GMT -8
I guess my first question is, how tall is the camper inside? Second question is, how tall are you? If the interior height is 6'1" like many of the old ham style Shastas, and you are close to six feet then add quarter inch VCT tiles, you might be making the inside of the trailer uncomfortably short. If 95% of the original tile is in good shape, would it be possible to replace those tiles, and maybe a couple more that you cut out in a random pattern, with something that contrasts with or complements the originals? If interior head room isn't an issue, then you should be fine with covering the old tiles as you described. Just remember that if there is asbestos, it only becomes a problem if it becomes airborne. We removed ours safely with the walls gone in a well ventilated area using plenty of very damp towels to keep the dust down.
