christinewv
Post by christinewv on Feb 21, 2017 4:44:56 GMT -8
Hi All - are there any links or tutorials as to how to check whether or not the foam from my 1969 scotty is usable? or exactly how to clean it with vodka? the website link to cushion recovery seems to be defunct. any help appreciated.
swirlygirls
Post by swirlygirls on Feb 21, 2017 8:13:41 GMT -8
Clean it with vodka? Do you mean you drink the vodka while you clean it?
theresa
Post by theresa on Feb 21, 2017 8:17:40 GMT -8
linkA quick Google search yielded several how-to tutorials. It's cheap enough to do. I'd try it and if it works, you've saved a ton of money over buying new. If it doesn't work, you're still not out much. EDIT: I just realized the post I linked to was about cleaning mattresses. The foam cleaning tutorial I'd read before was basically the same steps. People used varying amounts of vodka and some with/some without essential oils to add a fresher smell. Some people merely sprayed it onto the foam and let air dry. Others completely saturated the foam in a bin/tote, then squeezed it out and let it air dry.
Post by bigbill on Feb 21, 2017 17:14:28 GMT -8
They best way to determine if foam is reusable is to cover it with a barrier to keep you clean then sleep on it all night by morning you will know if it is worth the effort to clean it, most is not.
Post by kirkadie on Feb 21, 2017 21:22:32 GMT -8
Yep, Bill's right, but it might not even take till morning.
Post by Hamlet on Feb 22, 2017 19:32:07 GMT -8
Are you planning on cleaning them with the covers still on. Are the cushions all foam, or do they have springs? If they have springs, I'd try cleaning them. If it's a trailer from the seventies or later, the foam is probably polyurethane. It may clean a little more easily than natural rubber foam, which usually will have disintegrated at least somewhat after 40 years or more. Spring cushions are worth restoring/rebuilding, etc. It can be speedy, but they are gorgeous and can withstand a lot of wear.
