Post by danrhodes on Dec 4, 2016 18:34:35 GMT -8
Are they the same as a BBQ regulator? Amazon carries mostly 2 tank systems, so I'm not sure what to use for a single tank.
Post by mel on Dec 4, 2016 19:24:55 GMT -8
msgoehring
1957 Westerner Deluxe
Post by msgoehring on Dec 4, 2016 20:11:13 GMT -8
Trailers require low flow on the propane, meaning it doesn't come out as fast or in as great a quantity as a barbecue requires. In fact most camping equipment calls for low flow propane, not that people always do as suggested, we didn't until we had our accident in '97 and was educated better on proper use of propane.
Post by nccamper on Dec 4, 2016 20:17:07 GMT -8
I bought this one. www.vintagetrailersupply.com/One-Tank-Regulator-with-POL-for-Horizontal-Mountin-p/vts-628.htmA combination regulator; first stage reduces cylinder outlet pressure to 10 psi, and then second stage maintains a stable working pressure of 11” water column.
Inlet: Excess Flow POL, Outlet: 3/8” FPT, Horizontal Vent, 160,000 BTU/hr
For use on RVs with single vertical tank and horizontal tank.
UL listed: USA / Canada
Safety features: • Excess Flow Device: Ensures protection with all hose connections. Limits gas flow in the event of hose rupture or accidental disconnection. • Overpressure Protection Devise: Limits environmental propane release in case of regulator malfunction to a value less than 2 psi, significantly lower than that mandated by UL standard 144.
msgoehring
Post by msgoehring on Dec 4, 2016 22:32:22 GMT -8
Post by mrmarty51 on Dec 5, 2016 0:46:31 GMT -8
My BBQer has five burners. My camp trailer has three burners on the stove and one burner for the heater. I go to the dumps whenever I need a regulator. I always get those real nice ones that have the black hand nut so i dont have to use a wrench to change bottles. The BBQer regulator/hose has the left hand thread fittings. There is an acetelyne adapter that will take the 5/8ths l.H. propane fitting and convert them to pipe thread, I think it is either 1/4 or 3/8ths. From there they can be converted to fit the camper trailers. It works for Me.
Post by danrhodes on Dec 5, 2016 9:46:28 GMT -8
Post by mel on Dec 5, 2016 9:58:59 GMT -8
That is exactly what mine looks like dan
msgoehring
Post by msgoehring on Dec 6, 2016 10:08:27 GMT -8
Dan, I've been thinking about this since you posted it last night, and at first wasn't going to say anything, but after talking with Sam this morning, I just have to tell you my opinion on this regulator you've shown last.
I know Mel says hers looks just like it, but did you really read the description of it? Did you see that it's mainly used between a camp cook stove and a free standing gas BOTTLE. I asked Sam what that means to him, and he agrees with me that they are most likely meaning the small 1 lb disposable cylinders you buy from like wal-Mart and in fact when I search propane bottle that is the first thing to pop up. So I'm sure that one wasn't meant to be used on an RV, trailer or even a 20 lb tank like what is usually used on trailers.
Another thing that has me nervous was how you stated "Here is a cheaper single stage regulator that I might try instead." If you were replacing something like this for your home, would you go with the cheapest option, or the option that your positive is best and safest for your family? I was searching for the same type of regulator suggested by the experts at VTS, but for a little less price and shipping costs. The camco one I shared is also available at many of the online trailer supply stores, so I knew it was meant for a trailer. Sam stated that he would be going to our local propane supplier to get the correct regulator that they (the experts) recommend for trailers, and said that I might suggest the same to you. But I'll go one further and say that the place to check is a local trailer and RV supplier and/or repair shop so that you are guaranteed your getting the right information. You don't have to buy one from them, just find out what they recommend and then search for the best price for those.
I want you and your family safe in the trailer and I have a lot of doubts about using something so important to the proper functionality of the propane system that isn't rated or made for the purpose you'll be using it for. I'm a big proponent of keeping and using propane in trailers, it really is the best option for cooking and heating while camping. But only if it is done properly and everything is installed correctly for the purpose. I hope you'll take the time and do a little more research into the correct regulator before you buy.
Post by danrhodes on Dec 6, 2016 11:28:46 GMT -8
Dan, I've been thinking about this since you posted it last night, and at first wasn't going to say anything, but after talking with Sam this morning, I just have to tell you my opinion on this regulator you've shown last. I know Mel says hers looks just like it, but did you really read the description of it? Did you see that it's mainly used between a camp cook stove and a free standing gas BOTTLE. I asked Sam what that means to him, and he agrees with me that they are most likely meaning the small 1 lb disposable cylinders you buy from like wal-Mart and in fact when I search propane bottle that is the first thing to pop up. So I'm sure that one wasn't meant to be used on an RV, trailer or even a 20 lb tank like what is usually used on trailers. Another thing that has me nervous was how you stated "Here is a cheaper single stage regulator that I might try instead." If you were replacing something like this for your home, would you go with the cheapest option, or the option that your positive is best and safest for your family? I was searching for the same type of regulator suggested by the experts at VTS, but for a little less price and shipping costs. The camco one I shared is also available at many of the online trailer supply stores, so I knew it was meant for a trailer. Sam stated that he would be going to our local propane supplier to get the correct regulator that they (the experts) recommend for trailers, and said that I might suggest the same to you. But I'll go one further and say that the place to check is a local trailer and RV supplier and/or repair shop so that you are guaranteed your getting the right information. You don't have to buy one from them, just find out what they recommend and then search for the best price for those. I want you and your family safe in the trailer and I have a lot of doubts about using something so important to the proper functionality of the propane system that isn't rated or made for the purpose you'll be using it for. I'm a big proponent of keeping and using propane in trailers, it really is the best option for cooking and heating while camping. But only if it is done properly and everything is installed correctly for the purpose. I hope you'll take the time and do a little more research into the correct regulator before you buy. I agree after reading the description a bit further. There are units that look like mel link that are dual stage for interior use, so she's not wrong. My old unit looked like that as well, but I'm not the type to jump on something without a lot of research which I've been doing off and on for a week (btw, some scary stuff out there). Thanks for your concern....safety is always the primary reason we are all here and not painting and patching rot like the Pinterest brigade.
Post by Ten on Dec 9, 2016 5:53:17 GMT -8
I got thinking about the comment on using the old one with new connections, and wonder how many times that may have been done. I don't know what is inside the regulator's, but am fairly certain that if the condition of the lines are questionable, I sure would not want to trust an old regulator either. It could be scary if it were to fail while you are heating up your tea, and suddenly had flames licking up around the stove hood. Personally I decided on a new automatic-changeover reg (two-tank system) with braided stainless connection lines. The next owner may appreciate them someday.
