HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on Dec 3, 2016 14:41:37 GMT -8
If electricity is available is a small ceramic heater enough to keep you comfortable in a small camper if the temperatures drop in the mid 30's overnight? Danny
msgoehring
1957 Westerner Deluxe
Post by msgoehring on Dec 3, 2016 15:00:15 GMT -8
I'm sure you can find one that will work just fine. We use two older ones out in our garage and it stays about 60 - 65 on 30 degree nights and days. Ours are a few years old so I'm sure you can find better ones.
chametzoo
1960 Mobile Scout
Post by chametzoo on Dec 3, 2016 15:21:12 GMT -8
msgoehring
Post by msgoehring on Dec 3, 2016 17:09:57 GMT -8
HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on Dec 3, 2016 17:23:30 GMT -8
Chametzoo that heater is really big @ 15 x 27 x 6", I wouldn't know where to put it so it wasn't in the way all the time. I agree with the oil filled heater being too big for the limited space,in a larher camper I could see it being a better choice. Danny
Post by bigbill on Dec 4, 2016 6:28:27 GMT -8
I like a small unit with a slow blower speed as moving air feels colder. I think a couple of small units keeps the heat more even than one large unit plus usually quieter. But any heating device should contain a tip over switch and a over temp safety switch.
HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on Dec 4, 2016 6:52:20 GMT -8
I like a small unit with a slow blower speed as moving air feels colder. I think a couple of small units keeps the heat more even than one large unit plus usually quieter. But any heating device should contain a tip over switch and a over temp safety switch. Thanks for the reply Bill,I would think any of the new ceramic heaters would have the safety features.Danny
Post by SusieQ on Dec 4, 2016 21:55:11 GMT -8
I love my ceramic heater. Get one with a thermostat that you can set the temp. I have a small one and it works great.
Post by bigbill on Dec 5, 2016 11:46:02 GMT -8
I like a small unit with a slow blower speed as moving air feels colder. I think a couple of small units keeps the heat more even than one large unit plus usually quieter. But any heating device should contain a tip over switch and a over temp safety switch. Thanks for the reply Bill,I would think any of the new ceramic heaters would have the safety features.Danny Yes I think they are required by law but some old ones still exist. That is why I mentioned it.
57heaven
Post by 57heaven on Oct 11, 2022 16:42:35 GMT -8
Old thread but does anyone have a specific model of adjustable output electric heater that they've had good luck with? Looking for one for use in my camper which the body is about 13 1/2' long so not a huge space and not something that will be needed a lot but I'd still like to buy a good unit. Thanks
Post by vikx on Oct 12, 2022 13:06:51 GMT -8
Polaris is a good brand. Your trailer MUST be wired to carry the amp load (normally 13 amps). One big amp item at a time... In other words, don't curl your hair at the same time. LOL
newin62
1962 Shasta Airflyte
Post by newin62 on Oct 12, 2022 15:20:51 GMT -8
The propane lamp does a wonderful job of heating the dinette area when it's just a little cool outside night. My wife is insisting I reinstall the propane light on my rebuild for precisely that reason. Even the noise it makes gets to be endearing after a little wile.
aslmx
Post by aslmx on Oct 17, 2022 10:17:29 GMT -8
We used one of the radiator looking heaters. Always ran it on low. Did a great job but a little large.
Post by danrhodes on Oct 17, 2022 20:13:24 GMT -8
Polaris is a good brand. Your trailer MUST be wired to carry the amp load (normally 13 amps). One big amp item at a time... In other words, don't curl your hair at the same time. LOL I have my original 15 amp panel and it can't handle a tiny electric heater.
57heaven
Post by 57heaven on Oct 18, 2022 3:36:07 GMT -8
I also have the original glass fuse 15 amp circuit in my Pathfinder. I did use a small ceramic heater a couple weekends ago and it seemed to work okay. It didn't have an adjustable thermostat though so it is not one I want or regular use. I picked up a Honeywell model hhf360v last night. Going to give that a try and see how that works. It's not something that is going to be used an awful lot anyway.
