Post by mel on Nov 26, 2016 6:10:03 GMT -8
Post by nccamper on Nov 26, 2016 6:46:53 GMT -8
That does seem like a good deal.
They just show the stand. I wonder if this is the exact unit vikx had in a photo attached to the wall?
vikx?
Post by Ten on Nov 26, 2016 7:51:32 GMT -8
This is the suggested model. A quick run of the video makes me wonder how well this can possibly work in a 16-18 ft. camper if it is mounted and points only in one direction.
Post by vikx on Nov 26, 2016 22:55:52 GMT -8
These little Wave 3's will COOK YOU OUT of a canned ham! LOL. Seriously, unless it's freezing out, you will turn it off at night. $172.50 is a great price. For larger trailers, some might consider the Wave 6.
Post by Ten on Nov 27, 2016 4:39:17 GMT -8
I wondered about it after seeing the part about the radiant heating, since it seems not to heat the air. It does make sense it would work well in a small space. I still have this on my wish list for the Airflyte.
Post by nccamper on Nov 27, 2016 5:47:27 GMT -8
These little Wave 3's will COOK YOU OUT of a canned ham! LOL. Seriously, unless it's freezing out, you will turn it off at night. $172.50 is a great price. For larger trailers, some might consider the Wave 6. "Flush mounted and hung on 3 sturdy screws..." So there is no space needed behind the unit and it doesn't damage the nearby panel?
Post by Ten on Nov 27, 2016 16:09:37 GMT -8
I believe I read somewhere that the Wave 3 can surface-mount and effectively throw the heat outwards without need for any clearance space. I think (that is dangerous all by itself...) that there is a wall mount protector that recesses into the wall available and recommended for the Wave 6 and Wave 8.
Post by nccamper on Nov 27, 2016 20:08:02 GMT -8
I believe I read somewhere that the Wave 3 can surface-mount and effectively throw the heat outwards without need for any clearance space. I think (that is dangerous all by itself...) that there is a wall mount protector that recesses into the wall available and recommended for the Wave 6 and Wave 8. I also remember something about a wall mount protector but nothing comes up on google.
RinTin
Post by RinTin on Nov 27, 2016 20:36:33 GMT -8
Here's a pic of my older version Wave 6 installed with the recessed wall mount trim: These can indeed be safely surface mounted on a wall also. The manufacturer specifies a minimum height off the floor and a minimum unobstructed space in front of the unit. I don't recall anything about a wall mount protector but a dust cover is recommended as they are sensitive to dust.
Post by nccamper on Nov 27, 2016 20:53:11 GMT -8
Here's a pic of my older version Wave 6 installed with the recessed wall mount trim: These can indeed be safely surface mounted on a wall also. The manufacturer specifies a minimum height off the floor and a minimum unobstructed space in front of the unit. I don't recall anything about a wall mount protector but a dust cover is recommended as they are sensitive to dust. Rintin, it looks good. Unfortunately nothing comes up in google for a recessed wall mount trim on the wave3. Didn't the wave6 turn the camper into an oven?
RinTin
Post by RinTin on Nov 27, 2016 21:30:45 GMT -8
Here's a pic of my older version Wave 6 installed with the recessed wall mount trim: These can indeed be safely surface mounted on a wall also. The manufacturer specifies a minimum height off the floor and a minimum unobstructed space in front of the unit. I don't recall anything about a wall mount protector but a dust cover is recommended as they are sensitive to dust. Rintin, it looks good. Unfortunately nothing comes up in google for a recessed wall mount trim on the wave3. Didn't the wave6 turn the camper into an oven? I shut it down long before it gets too hot. If it starts to get cold, I fire it back up. No big deal. Rarely use it during the summer months, mostly for winter camping.
Post by vikx on Dec 3, 2016 22:58:03 GMT -8
The company says the Wave 3 CAN NOT be recessed...
msgoehring
1957 Westerner Deluxe
Post by msgoehring on Dec 3, 2016 23:34:51 GMT -8
but can it be hung on a cabinet door and used when the door is open like this??? 132_zpsea9c1910
Post by vikx on Dec 6, 2016 23:02:06 GMT -8
The cabinet door idea is workable, yes. However, the corrugated yellow "flex" line is not safe nor legal in an RV. A rubber hose is better, but still not up to code in some states. Do your research.
msgoehring
Post by msgoehring on Dec 6, 2016 23:54:53 GMT -8
The cabinet door idea is workable, yes. However, the corrugated yellow "flex" line is not safe nor legal in an RV. A rubber hose is better, but still not up to code in some states. Do your research. I knew about the flex hose, no way I was gonna use that, but I liked the location better than on the side of the wardrobe by the door. This way it'll be more centralized and warm the trailer more evenly I thought. Plus it'll be out of the way when not being used and I can have Sam build a shoe holder on the wardrobe instead 😁
