pauls
Heat gun
Nov 10, 2016 9:12:32 GMT -8
via mobile
Post by pauls on Nov 10, 2016 9:12:32 GMT -8
Have any of you stripped off exterior paint with a heat gun? Would this work? I am about 3/4 finished and the weather turned too cold to use the chemical stripper. My plan was to finish stripping, put in to winter storage and do the sanding and the rest of the prep in the spring. Thoughts?
Thanks
Paul
Post by nccamper on Nov 10, 2016 19:55:34 GMT -8
I don't think 0.19-.04 Aluminum will hold up to that kind of heat without ill effects. I've used Jasco stripper down to around 50 degrees.
