oddball
New Shasta owner.
Post by oddball on Nov 5, 2016 19:57:18 GMT -8
I am trying to register and title my 1961 Shasta Astrodome in Texas.
One of the fields on the application is "Carrying Capacity". If its over 4500#, it has to undergo annual inspection. No inspection is required if less than 4500#.
My research says the Empty Weight is 2100#. So I doubt the carry weight will be more than double that. However, I have not been able to find that spec. Does anyone know where I could find that specification?
Thanks!
Oddball
Post by vikx on Nov 5, 2016 20:06:22 GMT -8
I would say around 3500 lbs. That way, no inspection and I doubt you could get that much in the trailer...
Post by turbodaddy on Nov 6, 2016 4:29:07 GMT -8
Our 17' (14' box/w/cabover) 1965 FAN weighs 2800 lbs empty (with 2 group 24 batteries)and about 3200 fully loaded with water, food clothing and stuff.
HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on Dec 3, 2016 12:36:02 GMT -8
You would have to take a lesson from Lucille Ball in the movie the long.long trailer and load up a lot of rocks to reach 4,500 lbs. Danny
Vintagehotdog
Hi, we are Paul and Irvina, Currently rebuilding a 12' 1958 Easy Traveler
1962 Oasis 18'
Post by Vintagehotdog on Dec 6, 2016 16:11:33 GMT -8
There is no way I would tell them it's over 4500 even if was. I'd make them figure it out.
The real answer is I would think the axle capacity would be stamped on the axle or axle tag.
HOTRODPRIMER
1957 Shasta
Post by HOTRODPRIMER on Dec 6, 2016 17:39:35 GMT -8
You might try going to a salvage yard that buy scrap and they could weigh your camper for a few bucks, Danny
Post by turbodaddy on Dec 6, 2016 19:09:19 GMT -8
Get weighed, you might "wike" it. Our local recycler charges $10 to weigh a camper. Sounds silly, but remember to disconnect the tow vehicle.
bev
Post by bev on Dec 7, 2016 4:40:12 GMT -8
my axle has tags on the break drum. i have a 1970 shasta starflyte. my dry weight is 2500 lbs and my axle max is 3500 lbs. for your registration purposes i would state 3500 lbs bc its reasonable and most likely what you have .
