bullseye17
Post by bullseye17 on Aug 25, 2016 5:43:36 GMT -8
My trailer will have a city water hookup that is directly connected to the faucet, and no tanks onboard. My original plan was just to run a drain through the floor with a valve that allows me to close it off when not in use.
I know this is a no-no in many campgrounds, but we currently don't actually visit campgrounds often - we're usually on our own land, or friends and family.
That said, is there a better way to do this that is more campground friendly without having to add a tank? I have all of the parts to hook up the water to the sink, but no plans or supplies for a drain yet. One of the thoughts I had was just to carry an old water jug with me that I could use to hold greywater when needed.
Does anyone make drain kits or products that would be appropriate for this setup?
Any thoughts or insight would be very much appreciated!
chickenfarmer
1968 Fleetwing Wren
Post by chickenfarmer on Aug 25, 2016 7:21:29 GMT -8
I just got an extra city water inlet, punched the check valve out. I mounted it low thru the skin. They make portable grey water tanks with wheels, or rig up a container, connect with hose pipe.
Post by vikx on Aug 25, 2016 20:49:06 GMT -8
I add a barb to male 3/4 hose thread at the bottom of the drain tube. Very easy to connect to a tank or run away from the trailer.
msgoehring
1957 Westerner Deluxe
Post by msgoehring on Aug 25, 2016 20:58:49 GMT -8
kuuipoz
1969 Shasta Loflyte
Post by kuuipoz on Dec 3, 2016 21:30:32 GMT -8
I would love to know something about this as well. I just bought a small camper and I'm working out how I'm going to re-plumb it. I'd like to be able to have hot water, no point in having a shower if all I get is cold water out of it. I like the idea of not having to turn it on and wait for it to warm the water as well. On the other hand, would it suck too much electricity and pop the breaker? In that case, would I have to update all of the wiring? Should I do that anyway? Now my brain is on overload arrrgh!
Post by vikx on Dec 3, 2016 22:48:03 GMT -8
Take some time to study, Kuuipoz. Do you have a name we can call you?
An electric water heater won't work unless the system is upgraded. Little vintage trailers operated on 15 amps total, so it's hard to add much. They can be upgraded, but it must be done by a pro..
