Post by danrhodes on Jul 18, 2016 18:48:51 GMT -8
I always have to post my cheap-o ideas just to get them out of my head and get talked some sense. I have half a tub of roberts 2057 VCT adhesive I don't need and a sheet of laminate for my counters coming this week. How different could VCT and laminate glue really be?
Post by vikx on Jul 18, 2016 21:51:32 GMT -8
Laminate uses contact cement. You paint each surface and let it dry. The laminate is then eased into place and rolled. There is little danger of lumps and bumps with contact cement.
Honestly, I don't know how another glue would work. I suppose if it was smoothed properly, maybe. I would ask at the local flooring/counter top supply why/why not. Please share any ideas!
Post by danrhodes on Jul 19, 2016 5:07:03 GMT -8
Laminate uses contact cement. You paint each surface and let it dry. The laminate is then eased into place and rolled. There is little danger of lumps and bumps with contact cement. Honestly, I don't know how another glue would work. I suppose if it was smoothed properly, maybe. I would ask at the local flooring/counter top supply why/why not. Please share any ideas! I emailed Roberts. They said VCT adhesive was designed to allow the tiles to move so doesn't have the bonding power of a contact cement. I guess that's why some have problems with movement in their trailer floors.
Post by vikx on Jul 19, 2016 20:28:05 GMT -8
Thanks Dan. Didn't think it was the perfect solution.
Post by danrhodes on Jul 19, 2016 20:35:10 GMT -8
Thanks Dan. Didn't think it was the perfect solution. Cheap and perfect rarely intersect, but I like to try and keep the balance.
Dad Rambles
62 Shasta Airflyte
Post by Dad Rambles on Jul 20, 2016 3:16:51 GMT -8
Thanks Dan. Didn't think it was the perfect solution. Cheap and perfect rarely intersect, but I like to try and keep the balance. I think this should be the quote of the week, or possibly of my life. I try to walk this very thin line as well.
