Post by mel on Jul 11, 2016 10:27:04 GMT -8
Post by Ross on Jul 11, 2016 11:16:50 GMT -8
It looks fine to me. I believe that the grain pattern is different, because of the way the veneer was cut. It looks like it is a rotary cut veneer. Basically, the log was shaved like an endless pencil sharpener, thus causing a wider grain pattern in some areas and a tighter grain pattern in other areas.
edbrown
Post by edbrown on Jul 11, 2016 13:12:48 GMT -8
IMHO the center of the "left side closeup" looks like sanded through the veneer. I SHOULD be some kind of expert on sanding through the outer veneer. I've done it enough times. Looks to me like two places you're through the outer veneer, and a third where you are almost through.
Often a small sanding-through-veneer is not really noticeable. Stain if you like and finish with your favorite clear finish. Nobody but you will ever notice. But sand more delicately next time.
Post by danrhodes on Jul 11, 2016 13:39:20 GMT -8
IMHO the center of the "left side closeup" looks like sanded through the veneer. I SHOULD be some kind of expert on sanding through the outer veneer. I've done it enough times. Looks to me like two places you're through the outer veneer, and a third where you are almost through. Often a small sanding-through-veneer is not really noticeable. Stain if you like and finish with your favorite clear finish. Nobody but you will ever notice. But sand more delicately next time. I thought the same. In my experience, I didn't need to get the wood sanded so much, just scrape the old finish with a card scraper and a very light sand. The shellac evened every thing out nicely after 2 coats.
Post by nccamper on Jul 11, 2016 14:58:27 GMT -8
I'll take the middle position.
I think Ross is right about the wider grain. Ed may be right about small patches beginning to go through the veneer but not badly enough to make a huge difference when you shellac.
Anyplace you feel needs more sanding, hand sand with a fine grit just to be safe. If the mark expands you should stop.
