neilfreeb
Post by neilfreeb on Jul 11, 2016 5:37:52 GMT -8
Newbie so apologies if this article exists, but I have searched the forums and not found the complete solution. I'm assuming my McGuinness "Silver Queen" was originally silver so I want to remove the old paint - which I have seen articles for but I haven't seen much on polishing the aluminum - I seem to recall seeing something on Magic Blue or something similar so my question is: once I have striped the paint and cleaned it to remove residue, do I simply polish it? And then what should I coat it with? Thanks folks. Tried to paste one pic but don't think it worked. More pics in link below... IMG_2016.jpg s1293.photobucket.com/user/Neilfreeb/library/Silver%20QueenThanks!
yas
'63 Shasta Airflyte
Post by yas on Jul 11, 2016 6:15:30 GMT -8
I've never polished one, I'll let someone else chime in on the techniques. Here's the picture. Be prepared to spend a few hours, days, weeks, etc.
neilfreeb
Post by neilfreeb on Jul 11, 2016 6:58:09 GMT -8
Thanks Yas!
Yeah I have a few tins of elbow grease set aside.
Post by nccamper on Jul 11, 2016 11:03:29 GMT -8
I've used Gords and Blue Magic. I prefer Blue Magic because it's a paste and the results seem brighter. Polish has silicone in it that acts as a sealer. Airstream owners often use a system that slowly moves to a finer and finer polish. Much more work with better results. Some Airstream owners use an acid wash to prep the skin although I've only used it for windows. I would call the maker of whichever acid wash you're considering and ask the process. I use soft buffing pads for the first pass. You will need a lot of them. Then I hand polish with a microfiber cloth. Be sure to let the chemicals do the work of getting the paint off otherwise you will scratch the skin to the point it won't polish. I hope this helps.
neilfreeb
Post by neilfreeb on Jul 11, 2016 17:55:36 GMT -8
Thanks nc! This is very helpful.
Any preference for paint stripper?
Neil
Post by nccamper on Jul 11, 2016 18:39:08 GMT -8
Thanks nc! This is very helpful. Any preference for paint stripper? Neil Not patient? Love toxic chemicals? Jasco stripper. It works the best but wear heavy gloves and goggles. Have lots of time? Citrustrip. Works really well and not as toxic but you really need to let it sit for at least two hours. Wear the gloves and goggles just to be safe. Use a plastic scraper to get it off. If some paint remains reapply the stripper and rub gently with 00 or 000 steal wool. No sand paper. If any scratches appear shift to 0000.
neilfreeb
Post by neilfreeb on Jul 12, 2016 1:34:53 GMT -8
Great! Thanks so much.
