msgoehring
1957 Westerner Deluxe
Post by msgoehring on Jun 10, 2016 21:48:42 GMT -8
Hi all, Hubby and I decided to change the color of the appliances in Lil' Bit to better match the decor we have going. Right now they are yellow, which I like, but trying to tie that in with the teal and pink we have in the curtains and counter tops and table just would be way too busy. I probably should have thought of this when picking out the stuff, but I didn't and I really like the direction we are going now better anyway. The problem I've run into is the icebox door. All of the hardware, hinges and handle, are riveted on. In fact the door itself is riveted together. The door is much heavier than it looks so I have no clue what is inside it. The powder coater I talked to said would need to have all the trim and hardware removed from anything they work on. I have no idea how to remove that stuff from the door. I was also going to replace the gasket around the door, but it is sandwiched between the inside and outside so how would I do that??? I don't know if it's possible to drill out the rivets and then replace them. The only thing close to rivets I'm accustomed with are eyelets and I have tools to install those, but not in the way this is put together. The eyelets are put through holes then the setter is put in the middle and you hammer it to flatten the back. That won't work here. So do any of you have experience with taking apart an icebox door like this one, or any advice on how I could get done what I wanted to do?? TIA
edbrown
Post by edbrown on Jun 11, 2016 7:31:30 GMT -8
The only way to remove those rivets is to drill them out. Use a drill about two or three times the diameter of that little center hole. I like using around a quarter inch. Drill carefully and you'll take the top off neatly without damaging the panel. The back side should push out, at most taking a tap with a punch or nail set tool. The problem comes when you want to reassemble. Pop rivets are easy to install but stick up a lot on the back side. They aren't all that strong but would work IF there's enough space for the part that sticks up on the back. You probably will have to use squeeze type rivets. Those are harder to install, much stronger, and flatter on the back. I googled "Hand rivet squeezer", and found tools like this: www.pilotshop.com/catalog/topages/handrivetsqueezer.php?utm_source=google&utm_medium=cse&utm_term=12-01461&gclid=CjwKEAjw7e66BRDhnrizmcGc8VcSJABR6gaR3I3o9cwtxoFuB2k6VjkRB6wt6Hd9FcFdDrdetGc86hoCvcDw_wcBI've never actually used one of these. Anyone else have experience with them?
Post by Hamlet on Jun 11, 2016 12:45:18 GMT -8
We just did a really, really good job of masking the hardware before we painted Hamlet's icebox, and it turned out just fine. Six years later, it still is in good shape. Dunno if this would work if you were planning on having it powder coated, but I doubt it.
msgoehring
Post by msgoehring on Jun 11, 2016 15:26:16 GMT -8
We just did a really, really good job of masking the hardware before we painted Hamlet's icebox, and it turned out just fine. Six years later, it still is in good shape. Dunno if this would work if you were planning on having it powder coated, but I doubt it. Yeah, the people I've spoken to (got a hold of a couple today, believe it or not) all say that we need to remove any trim and hardware from what we want powder coated. I know I could paint the door like they did originally, but I really want all the appliances to match since they are so close together. I'm even getting the hood powder coated so it matches. Guess that means I get to buy another tool I'll probably never use again. Bought a soldering iron today so I can make a vintage radio I bought able to play my mp3 player. Don't know if I'd ever use it again, but we have it now
chriss
Post by chriss on Jun 26, 2016 5:49:55 GMT -8
I repainted my icebox. It was manufactured by Ward, but looks similar in construction to your's. I drilled out the rivets and separated the panels. There was a wood frame inside. I painted the panels, rebuilt the wood frame, then used tiny screws instead of rivets to reassemble the door. Screws went into the wood frame. I also insulated the door with foam.
Post by vintagebruce on Jun 26, 2016 11:14:33 GMT -8
msgoehring said " Bought a soldering iron today so I can make a vintage radio I bought able to play my mp3 player. Don't know if I'd ever use it again, but we have it now." Have no fear, tap into this you tube vid and then keep opening the ones available on the right, and you should be able to experience the joys of soldering iron ownership. www.youtube.com/watch?v=YbuTtoqnijg
