larky
1966 Shasta compact
Post by larky on May 16, 2016 15:58:32 GMT -8
While working in the bathroom of my 1968 travel trailer, I discovered an outlet near the toilet that is wired to the 12 v D/C supply. It's a regular outlet that looks like the rest of the ones through out the camper. It looks as if it came that way from the factory. Can anyone explain this?
Post by vikx on May 25, 2016 20:36:49 GMT -8
What you describe is far from normal. Even back in the day, using 110 outlets for 12 volts was not legal. I'm thinking a PO added the outlet? If your toilet is a Monomatic, it uses 12 volts to power the flush motor. Do you have any photos, especially of the wiring?
