windborn
1957 Sportcraft 15
Post by windborn on May 12, 2016 8:18:45 GMT -8
Hi y'all. I'm still trying to figure out what to do about finishing my wood. Sorry for all the posts! Unfortunately I'm on a deadline to get my camper out of the yard it's in now, and this weekend is supposed to be shellac time for half of the camper. I don't need my panels to be an exact match, but I don't want them to clash horribly either. Unfortunately, that's what they're doing right now. The amber shellac is making my birch just look so yellow-y/orange-y. The original fir (or whatever it is) is too dark for my liking, but I think it has a much nicer tone. I bought some Terra Mixol but that only seemed to darken the orange of the shellac. Should I consider my options for stain underneath shellac? I don't need the wood to be darker necessarily, I'd just like it to have a warmer, reddish tone. Should I just give up and continue down the path of having a quirky camper? Anything I use needs to be something I can get at a hardware store as I don't have any more time to have things shipped
windborn
1957 Sportcraft 15
Post by windborn on May 12, 2016 8:20:26 GMT -8
Looking at this picture now, it doesn't do justice to how orange the birch looks and is making the fir look a lot darker than it really is.
Post by danrhodes on May 12, 2016 8:40:27 GMT -8
Are you able to switch out the birch for Oak or another heavier grained wood? Shellac is likely not the answer here, no matter what wood you end up with, you'll need some stain to match the dark color of that old fir.
Post by nccamper on May 12, 2016 12:14:53 GMT -8
The fur looks brown/red in this photo. I agree, shellac may never be the answer. You have wood that you haven't touched with shellac? If yes, I would try stains. Home Depot has a wide variety of minwax stains. It is hard to know how wood will accept stain without trying. Even Shellac varies based on the wood. top birch with two coats of Amber, bottom with 4 coats. See how how red the top is? I might also consider a Penofin Bamboo Oil. I have a lot of different stains here if you want a quick test board on raw birch I can show you a few options. ---- one more thing, mixing wood has always given me indigestion. Adding to that, new wood of one type and old wood of another... new pine above with Mixol tinted shellac, old birch below with Amber mixed with clear. Below, Mixol tinted Amber. Three coats, then four in the middle then five on the left. But there is no guarantee your birch will do the same thing with multiple coats. A side note you probably already know, you can't stain wood you have shellac on now.
windborn
1957 Sportcraft 15
Post by windborn on May 12, 2016 15:05:14 GMT -8
Thanks, guys. Yeah, luckily all the wood right now is unfinished, so I still have options. There's no way I'll be able to replace the birch as I've already spent the time and money on replacing those walls. The original plan was to just re-paint the two fir walls, but I really liked the look of the grain so spent a lot of time sanding them down. I guess I could still paint them and call the all the sanding an arm workout. "Mixing wood has always given me indigestion." You're going to need a lot of tums if you ever step into my camper. Though it's pretty crazy how even two panels of birch can react so differently to the same finish. I can see how this would drive you insane.
Post by danrhodes on May 12, 2016 15:46:16 GMT -8
Uneven birch finishing is what got me to finally take off my perfectionist hat and just work on finishing the thing. Two lots from the same manufacturer can take shellac so dramatically different, you need to be a fine cabinetmaker to mix up a finish that matches.
windborn
1957 Sportcraft 15
Post by windborn on May 12, 2016 16:54:02 GMT -8
My grandfather was a fine cabinetmaker. He's probably out there somewhere shaking his head in disappointment right now...
I've done a little more reading about staining birch and the potential for blotchiness has me worried, so I'm not sure where that leaves me. I guess I'll have to make some decisions tomorrow. I hate to say it but I'm even beginning to reconsider painted walls and a shellacked birch ceiling like I planned on before I even started digging in.
Post by nccamper on May 12, 2016 19:21:03 GMT -8
A late night experiment just for you. Just one coat of a few stains I have in the paint closet. A Second coat would make the colors deeper and smoother but this gives you a good idea. Minwax Gunsmoke is very dark red/brown. It may work. Penofin bamboo oil is my favorite. On old wood (stained 50 years ago) it looks like this... Here are a few more options. Rusto Light Walnut may also work. Only way to know is experiment. Would you like to see how a coat of amber shellac changes the samples? I can put a coat on in 30 seconds tomorrow.
windborn
1957 Sportcraft 15
Post by windborn on May 13, 2016 3:13:16 GMT -8
nccamper, you are the best! I owe you a beer! I also really like the bamboo oil and have fawned over that example you've posted before. I was avoiding it because it was something I couldn't get at Home Depot, but the Penofin website has a few options for where to buy near me, so I'll give places a call this morning.(http://www.penofin.com/homeowner-resources/where-to-buy)
You haven't had any issues with blotchiness when staining birch? The rest of the internet seems to think that's a huge problem.
I agree that the two colors you picked out would work to match what I've got, but I have some decisions to make about if I want my camper to be that dark. I've said it before and I'll say it again: it would have been a whole lot easier to just replace these two old panels!
Post by nccamper on May 13, 2016 4:02:49 GMT -8
As far as blotchy goes, they make a wood conditioner (clear liquid) to put on soft wood (like pine and birch) first that helps. I've found that more than one coat of stain helps smooth things out. But it does gets darker the more you lay on so you really need to test first.
On my latest Shasta the rear panel, center roof and front all needed replaced. Basically every other panel. The roof framing was in excellent condition so I struggled to get the new grain and tint to match the old and eventually gave up, took all the roof framing out front to back just for esthetic reasons.
I've seen campers where the contrasting grain is actually a nice accent. But it needs to seem deliberate. Like all of one wall or the ceiling is unique. Not like a patchwork quilt.
Post by nccamper on May 13, 2016 8:00:41 GMT -8
Another test. I added two coats of amber shellac to the bottom. You can see there is a serious change on some stains. Your birch may have slight differences in shade. Only one way to find out.
windborn
1957 Sportcraft 15
Post by windborn on May 13, 2016 15:03:43 GMT -8
Thanks again nccamper! We need to pin these swatches somewhere for other people to check out. I ended up getting really lucky today. I had plans to drive around town looking for the right stain for my birch. Though once I got to my trailer and had some more scrap wood available I wanted to give one more thing a shot. I tried the amber shellac with the Terra tint on bare wood and it did the trick! It's the right darkness for what I want but it doesn't have the yellow-orange tint to make it clash with the old fir. It's always hard to get a good picture but this gives you an idea. And here's a description of all that's going on here. So you can see that the terra tint on top of amber shellac was still orange, but on bare wood is reddish brown. Also, despite what you told me nccamper, I tried some Mixol in clear shellac to see what it would do. It darkened it up a bit, but I don't think it's worth the effort. One thing I really like about this is that since it's darker, I need to put less coats on and the grain shows through better. Thanks for your moral support during my minor freakout, nccamper and danrhodes
Post by nccamper on May 13, 2016 15:10:41 GMT -8
Excellent. So the tint absorbed into the bare wood and brought out a different shade to build on. I think you're on to a real solution... and I learned something new. -- A photo I came across.
