roktac
Post by roktac on May 3, 2016 13:43:09 GMT -8
Post by vikx on May 3, 2016 22:05:28 GMT -8
The back panel doesn't look too bad. If it's not delaminated, might be savable. Add extra cross sticks front and back for stability, Shasta was lacking there...
roktac
Post by roktac on May 4, 2016 7:35:48 GMT -8
The back panel, I'll show another pic today was more rotted on the inside, so it's gotta go. I'm hoping the .20 birch ply I found will work. I might end up doing some sanding to make it work, can't find 1/8 birch anywhere around here. I was plan in on adding a 1x4 across the back and extending all the support frames to be flush with the wall... Just have to get the 3/4 ply strips made for in between. I am going to remove the awning rail completely today, so I can peel back the skin, far enough to see the side walls and floors in rear.
roktac
Post by roktac on May 8, 2016 11:12:37 GMT -8
Quick question, I am starting to replace some framing. The original boards are 1.75 , the new boards I got are 1.5 (1x2) I know If I use the thinner boards I have to make sure it all lights up, has anyone else used th thinner boards? I'm guessing it's not a big deal.. Advise?
Post by nccamper on May 8, 2016 15:50:03 GMT -8
Quick question, I am starting to replace some framing. The original boards are 1.75 , the new boards I got are 1.5 (1x2) I know If I use the thinner boards I have to make sure it all lights up, has anyone else used th thinner boards? I'm guessing it's not a big deal.. Advise? You're talking about how wide the boards are, thickness being the same 3/4"? Most of us increase the width of the framing a little where the shape allows. If it is a wall (flat) you might consider ripping 2" or more from a wider board.
roktac
Post by roktac on May 18, 2016 21:14:17 GMT -8
Post by nccamper on May 19, 2016 20:26:15 GMT -8
roktac
Post by roktac on May 29, 2016 9:56:58 GMT -8
Latest update.... This was before and after lots of work, but really happy... Not perfect but I am new to this and still learning.
Post by mel on May 29, 2016 12:32:01 GMT -8
Looks great so far!
Deleted
Post by Deleted on May 29, 2016 13:20:17 GMT -8
Good job! Bringing back wood is so rewarding, all the more so when it's on an iconic Shasta. Looks good to me!
roktac
Post by roktac on May 29, 2016 14:26:52 GMT -8
Thanks!! Hope to have the replacement panel back in by tomorrow
roktac
Post by roktac on May 30, 2016 13:41:26 GMT -8
Back panel day now to figure out my wiring and insulate ... Maybe get skin back on today we will see
Post by vikx on May 31, 2016 20:35:00 GMT -8
Don't forget backers for light flanges and other things. Come in very handy and lend a lot of support...
roktac
Post by roktac on May 31, 2016 21:28:17 GMT -8
Quick question, I am trying to replace the back bed/couch... Is a futon matress a good bet? PO had put In a regular matress (not sure how he go it in there) luckily he didn't mess up the original sliding couch/bed.
Post by nccamper on Jun 1, 2016 4:33:20 GMT -8
I turned the couch/bed into a permanent bed on our latest camper. We bought a Walmart memory foam mattress (Full size) on sale for $150, took the cover off and cut it down to 48". My sister trimmed the cover to fit. I like the look of the goucho but it's not as comfortable as a real mattress.
