tikimitch
1974 Go Tag-A-Long
Post by tikimitch on Apr 20, 2016 5:01:21 GMT -8
Hello All!!
I have about an 1/8" gap between the subfloor and the wheel wells in my trailer. Completely open to the outside. What is the preferred method for sealing this up from moisture and critters? Originally, they just laid the vinyl flooring over the gap.
Thanks!!
trotwood56
Post by trotwood56 on Apr 20, 2016 5:14:01 GMT -8
I used a petroleum based sealant that never hardens so if there is flex or the wood expands or ahrinks I dont have to worry about cracking. It was some kind of roof/gutter sealant super sticky but flexible also the oil base repels water Thats Just what I did.
Post by cowcharge on Apr 21, 2016 11:53:44 GMT -8
Expanding foam would probably work well too. That's what I used where the propane lines come up through the floor.
Post by nccamper on Apr 21, 2016 19:22:30 GMT -8
I'd first poke around to make sure the gap isn't actually rotten wood that needs repaired.
Post by vikx on Apr 21, 2016 21:43:10 GMT -8
I agree with NCcamper. A wheel well should NOT have gaps. They are tight to the floor or underneath, depending on construction type. I would do some serious looking before adding any sealant.
Post by mobiltec on Apr 21, 2016 21:44:42 GMT -8
PHOTOS!
Post by danrhodes on Apr 22, 2016 10:25:24 GMT -8
Mine mounted from below, so I used putty tape, then gooped the gap inside with gutter seal.
Post by cowcharge on Apr 24, 2016 15:30:00 GMT -8
Is the gap a space between the wheel well and the overlapping floor (a gap because of a difference in height of two layers), or a gap where the floor isn't wide enough to reach the wheel wells (that you can see straight down through)?
Post by mobiltec on Apr 24, 2016 18:06:01 GMT -8
Is the gap a space between the wheel well and the overlapping floor (a gap because of a difference in height of two layers), or a gap where the floor isn't wide enough to reach the wheel wells (that you can see straight down through)? The exact reason I asked for photos.
tikimitch
1974 Go Tag-A-Long
Post by tikimitch on Apr 28, 2016 6:06:33 GMT -8
Sorry I have not been on lately. Upon further inspection, the gap is not actually an open gap to below but just a gap where the plywood flooring does not go all the way up to the metal - the wood is solid all around the wheel well. I don't think it is any reason for concern after looking at it more closely - sorry for the false alarm :-) I am a newbie!!!
