Post by mobiltec on Aug 23, 2013 20:12:59 GMT -8
Post by universalexports on Aug 23, 2013 20:15:08 GMT -8
that for sure could be very handy.
Post by mobiltec on Aug 23, 2013 20:19:56 GMT -8
I use mine all the time..... Just lost a pair that I have had since 1992 so I had to order another.
txoil
1960 Shasta Deluxe 19
Post by txoil on Aug 24, 2013 6:50:29 GMT -8
I have a question...our camper was put together with screws having a sort of 'dogbone' or sideways eight shaped recess for the driver tip. None of the tools I have fit these screws and it is very labor intensive to dig each one out, with vice grips, a myriad of screwdrivers and much foul language. Larry, do you know what these profile screws werew called, and if so, is there anything currently available which will work on these *$#& screws?
Post by mobiltec on Aug 24, 2013 7:17:59 GMT -8
I have a question...our camper was put together with screws having a sort of 'dogbone' or sideways eight shaped recess for the driver tip. None of the tools I have fit these screws and it is very labor intensive to dig each one out, with vice grips, a myriad of screwdrivers and much foul language. Larry, do you know what these profile screws werew called, and if so, is there anything currently available which will work on these *$#& screws? I have no idea what you are talking about txoil... How about a photo? Bill will probably know what they are and what kind of tool is needed.... The trailers that I have worked on have all been philips head screws as far as the 50s were concerned. In the early 60s they started using hex head screws.
Post by bigbill on Aug 24, 2013 10:26:52 GMT -8
I think you are talking about clutch head screws they were used in many campers I know the Banner brand used them. in the 60s. You should be able to purchase the proper size at your local hardware but take a screw with you as they came in different sizes. if they don't have a screw driver check for a insert bit, some sets of bit assortments have them also.
Post by mobiltec on Aug 24, 2013 14:28:01 GMT -8
See I told ya Bill would know. LOL....
61 Shasta
Post by 61 Shasta on Oct 12, 2013 14:01:07 GMT -8
I have a set that came in a ratchet screw driver I have had for a few years and another that came in a combination set I purchased from Black and Decker. Good luck.
Aloha!
1964 Shasta 1500
Post by Aloha! on Nov 26, 2013 10:00:54 GMT -8
Learning all about tools one tool at a time. Now adding the Screw Pliers to my collection. My question -- is there a difference, that matters, between the Engineer PZ-58 Screw Pliers GT, Engineer PZ-57 Screw Pliers M2, Engineer PZ-55 Screw Pliers, and/or any of the other myriad of Screw Pliers? All listed are carried by Amazon. Nearest Lowes does not carry any under any name pushing a screw extractor set instead. Thanks in advance.
Post by mobiltec on Nov 26, 2013 19:51:15 GMT -8
I can only speak about the screw pliers I showed you because those are the ones I have. I could not find them anywhere else but on the internet. And I lost the originals that you saw in the Deville and Shasta photos. They were even better but they are not made anymore for some reason.
I love the ones I have but you still need to bang on the screws from the side with a flat screw driver much of the time. And sometimes with a Philips. I am pulling screws out of the 57 Westerner right now and these are the absolute worst I have come across. Some of them have taken me up to ten minutes to get one screw out.
