tikimitch
1974 Go Tag-A-Long
Post by tikimitch on Mar 24, 2016 10:44:18 GMT -8
I am pretty sure I know the answer I am going to get but thought MAYBE someone has a good trick to use. The rear floor panel in my '74 Go Tag-a-long has two holes where the plumbing went down through the floor. I am getting rid of the black water tank and running the grey water to a different area so I don't need the holes. I know I should remove the whole panel and replace with new wood, but if there is some way to "fill" the holes and then put the new tile down over it I would love to hear your ideas.
Thanks!
Post by bigbill on Mar 24, 2016 11:19:29 GMT -8
Take a board larger than the hole screw to bottom side of floor securely then cut a plug to set in the hole and glue it in, after it dries fill with leveling compound and sand smooth then install new tile.
tikimitch
1974 Go Tag-A-Long
Post by tikimitch on Mar 24, 2016 16:14:24 GMT -8
Well there you go - thanks bigbill!
yas
'63 Shasta Airflyte
Post by yas on Mar 24, 2016 17:03:53 GMT -8
That's what I did on my Compact. Someone had put a nasty toilet in the closet.
chriss
Post by chriss on Mar 24, 2016 19:05:32 GMT -8
Another alternative is cut a patch piece to fit snugly in the hole, then gorilla glue it in. I've patched a couple holes in my floor this way. Sand flush on both sides and paint underside to match whatever coating you have and it will be undetectable. Gorilla glue is amazing stuff.
Post by mobiltec on Mar 24, 2016 19:34:07 GMT -8
Take a board larger than the hole screw to bottom side of floor securely then cut a plug to set in the hole and glue it in, after it dries fill with leveling compound and sand smooth then install new tile. The only way I do it... There are always holes to plug...
tikimitch
1974 Go Tag-A-Long
Post by tikimitch on Mar 28, 2016 6:13:54 GMT -8
I did this over the weekend. I painted the underside of the boards matte black to match the soundboard that is underneath my floor (just like I saw in Mobiltec's videos), and filled in around the plugs. Just need to sand 'em smooth now. Thanks for all of the help. Many more questions will be coming over the next year I am sure!
