pnwmom10
Post by pnwmom10 on Mar 15, 2016 21:39:26 GMT -8
Its been a dream of mine to restore a camper! Today I bought a 1970 Ideal Camper for cheap. It has obvious water leaks. The previous over "tried" to restore it but now its basically just a blank canvas. No fridge, stove, sink, heater nothing but the bones. I started taking the paneling out and found water damage in the front left and the roof. What would the first step be in restoring this. I would like to reseal? all the trim and do some type of sealant to ensure my hard work is protected. Teach me your ways! Is it really hard to take the outside siding off to see the damage? as easy as unscrewing the screws and pulling off? The electrical somehow is in great condition and works great. Also can I pretty much make up my own floorplan for anything? Where should the majority of the weight go front, back, middle? I want my camper to be as simple as possible. I will be using a hand pump with simple grey water tank and clean water tank under sink. Icebox for fridge, propane stone for outside. I will try to post pictures as I go and any help, tips, or comments on how to do this the correct way would be great. Thanks guys!
pnwmom10
Post by pnwmom10 on Mar 15, 2016 21:46:15 GMT -8
Also best camper websites to buy supplys from?
Post by vikx on Mar 15, 2016 22:06:14 GMT -8
Welcome PNWmom!
Start by taking one step at a time... the skins must be lifted to do repairs. How far you need to go depends on the damage to your trailer. The worst thing you can do is GUT the inside. Cabinets and closets lend a lot of structural strength.
Lifting the skins involves removing edge screws and trim, then picking multiple staples, but is basically very easy to do.
As above, the floorplan makes a difference in structural integrity. There's no hurry. We are here to help. Do some reading and enjoy.
pnwmom10
Post by pnwmom10 on Mar 15, 2016 23:04:28 GMT -8
Thank you vikx! Unfortunately the previous owner had pretty much taken everything out, including cabinets and closets. I plan to install cabinets and shelfs. Will that increase the strength of the camper? What are some things i can do to increase the over stability of the camper?
Post by Hamlet on Mar 16, 2016 10:24:37 GMT -8
You don't say what model Ideal camper you have, but you might want to start by looking online to see if you can find pictures or a schematic of the original layout. That'll give you an Ida of what you will need to re-invent. With it gutted, you do have the capability of redesigning the floor plan, as long as there are adequate cupboards, closets, etc to lend support. Several members have done this and have wound up with gorgeous, totally vintage looking trailers.
And vikx is right, lifting the skins is time consuming, but as you read through various posts, you'll realize that without the cabinetry, you really HAVE to work from the outside in. Good luck, be patient, and keep asking questions. If you're west of the Cascades, the rain should diminish in the next few weeks, and you can begin the adventure!
Post by vikx on Mar 16, 2016 10:28:25 GMT -8
As long as you do proper repairs to the skirt boards, wheel wells and other rotted areas, you should have a strong camper. That is the first order of business; get rid of the rot.
Then take a look at similar trailer size/floorplans, then replace the cabinets. The closet adds a lot of support because it is floor to ceiling. The lower cabinets help secure the walls and keep things square. Shelves are fine if they are built as open cabinets sans the door.
Simple is good as long as the structure will take bouncing down the road. It's amazing how much our little trailers "move" during travel.
