icanned
Insulation
Feb 29, 2016 12:20:18 GMT -8
via mobile
Post by icanned on Feb 29, 2016 12:20:18 GMT -8
Hi all! I'm restoring a canned ham for the 1st time and had some question regarding insulation. It had a foil type when I tore it down. I was thinking about installing a rigid foam board type R13 insulation I between the framing an inner/outer skins. Any feedback, info, or suggestions are greatly appreciated! Thanks Isaac
Monabones
Insulation
Feb 29, 2016 12:31:02 GMT -8
via mobile
Post by Monabones on Feb 29, 2016 12:31:02 GMT -8
Thats what I used and it works great. Easy fast and also water resistant. Plus the rating factor is a plus.
icanned
Insulation
Feb 29, 2016 13:03:34 GMT -8
via mobile
Post by icanned on Feb 29, 2016 13:03:34 GMT -8
Great! Did you leave an air gap?
Monabones
Insulation
Feb 29, 2016 17:27:18 GMT -8
via mobile
Post by Monabones on Feb 29, 2016 17:27:18 GMT -8
According to the manufacturer of the foam board I used you don't need a air gap. However my trailer did have a small air gap between skin and birch. This was because my wall cavity is 1.5 inch thick and the insulation was 1.25 inch thick.
HeavyD
Post by HeavyD on Feb 29, 2016 18:04:39 GMT -8
I used 1.5" rigid foam. I rough cut it and glued it in with foam adhesive. Then I spray foamed the gaps and trimmed it flush. Here is a picture after I filled the gaps, but before I trimmed it.
Post by mobiltec on Feb 29, 2016 21:42:33 GMT -8
Post by cowcharge on Mar 1, 2016 6:46:43 GMT -8
I used 1.5" Tuff-R sheets, it has the highest R-value I could find (6.5/inch), and is silver coated on both sides so all I had to do was tape over the seams and frame with aluminum tape to make a complete vapor barrier. My camper has tapered rafters that are 3.5" thick in the middle, so the R-value of the center foot or so of my roof is 22.75. Been out at 14 degrees, and the old furnace kept it a toasty 75 inside...
Post by Hamlet on Mar 1, 2016 17:33:46 GMT -8
Is that cotton candy? ;-)
