Post by mel on Feb 18, 2016 5:16:49 GMT -8
I tried to clean up my drawer pulls yesterday, but I am not happy with the results. I few of them look ok enough to use, 2 of them will not shine up at all and are pretty dull, those are the ones started off green from ageing. Has anyone spray painted them chrome? how have they held up in time?
MarthaS
1965 Friendship Vacationaire
Post by MarthaS on Feb 18, 2016 6:18:05 GMT -8
I'll be interested in the replies because I will need to spray paint our table leg with Chrome-like spray.
Post by nccamper on Feb 18, 2016 7:47:50 GMT -8
I used chrome paint on a license plate holder. It matched the chrome circle cap/name cap but as you can see the paint doesn't have the same reflective quality. Any raised marks will still show.
zipper
1966 zipper , 1961 trotwood
Post by zipper on Feb 18, 2016 7:47:57 GMT -8
I sprayed the hubcaps on my 1962 Trotwood with the chrome spray, they turned out well, I hope your drawer pulls turnout well.
MarthaS
Post by MarthaS on Feb 18, 2016 7:54:21 GMT -8
Can you share what type of chrome spray you used?
Post by nccamper on Feb 18, 2016 8:15:58 GMT -8
Overall I was happy. I can't remember if I bought it at Lowes or Home Depot. I would buff the handles with steel wool to remove some of the pitting. And try it on one first. My guess is that paint on handles will need redone every couple of years.
Post by kirkadie on Feb 18, 2016 9:26:42 GMT -8
Post by mel on Feb 18, 2016 9:55:04 GMT -8
I just picked up some rustoleum spray paint, the same as the one pictured in nccampers photo. But I didnt think about the primer while I was there, Ill have to pick some up. I will post photos in a few days after they are done and dry. I figure I will just try it out and see how they look, eventually down the line if Im not happy with them I can just buy the new ones from VTS for 6.50 each nccamper did you use primer? also I have stripped the back end of one of my screws holding the 5th one in, I cannot get it out. My next thought was to take the multi tool and either saw the screw head off(if I cant get behind it) or saw a slit into the screw to put my screwdriver. Any one else have any better ideas? the head is not big enough to hold with plyers, its too rounded.
Post by vikx on Feb 19, 2016 21:33:20 GMT -8
Spray some blaster on the screw before going further. I think slotting the head is a good idea or cutting the head off. Where there's a will, there's a way...
Post by nccamper on Feb 20, 2016 6:28:02 GMT -8
I primed first. Light coats and let dry completely. Kirkadie, alsacorp.com/killer-chrome/ looks excellent. A little better reflectiveness than Rustoleum. I wonder how it would hold up?
Post by kirkadie on Feb 20, 2016 14:33:01 GMT -8
I'm guessing if the hot rodders use it, it should do OK. I'm thinking of using it on Scotty's hub caps, since, even though it's pricey, it's cheaper than some OEM Scotty caps I've seen on eBay.
Post by mel on Feb 20, 2016 16:56:45 GMT -8
I learn the hard way sometimes, so I sprayed one of my handles and one knob just to see how I liked it. The directions said if you wanted to add another coat to do so before the first hour or after 48 hours, so I put on two coats. Then I kept reading the directions and it said it should be dry to the touch after an hour, so I went to pick them up thinking they would dry, but guess what? they were not. haha so I let them dry and had to strip the finish off, now they are ready to start over again.
Post by mel on Feb 27, 2016 10:55:35 GMT -8
Here are how they turned out, I just did two for now to see how I like it. Going to stare at them for a few more days before I make up my mind. Front is original, back is spray painted. bottom two are sprayed one of them had some rust sticking up that would not come off, top is original
Post by SusieQ on Feb 28, 2016 20:31:02 GMT -8
I learn the hard way sometimes, so I sprayed one of my handles and one knob just to see how I liked it. The directions said if you wanted to add another coat to do so before the first hour or after 48 hours, so I put on two coats. Then I kept reading the directions and it said it should be dry to the touch after an hour, so I went to pick them up thinking they would dry, but guess what? they were not. haha so I let them dry and had to strip the finish off, now they are ready to start over again. I think we are twins who have never met. I did the same thing with my tag light. It still has a thumb print in it. And that was after I redid it.
Post by nccamper on Feb 28, 2016 21:22:11 GMT -8
A trade off. You lose something and gain something with the spray.
Kirkadie, alsacorp.com/killer-chrome/ looks like it might be better.
