Errol Strummer
1959 Airflyte
Post by Errol Strummer on Aug 14, 2013 13:03:43 GMT -8
Here is our old ice box once I pulled it out. This thing would only hold Block ice for like 12 hours we need to do something about this. The picture shows the current insulation under some cardboard should I leave it and cover with Aluminized foil insulation or can I just take all the old surf off and use new product everywhere.
zipper
1966 zipper , 1961 trotwood
Post by zipper on Aug 14, 2013 17:39:56 GMT -8
My icebox had nothing on it, I made a cardboard box around it. Sprayed the space with great stuff spray foam. My thought this would be the best insulation and keep the box from sweating inside the cabinet... so far so good
Post by vikx on Aug 14, 2013 21:19:54 GMT -8
I use styrofoam, a big 2" piece in the cabinet bottom, and 1" on the back and sides if possible. Then I insulate the entire ice box as thick as it will slide in the hole. As a final step, insulation over the top if I can reach. The more the better in my book.
Errol Strummer
1959 Airflyte
Post by Errol Strummer on Aug 14, 2013 22:19:51 GMT -8
Thanks Vikx I ended up buying a sheet of 1" polyurethane board today and I'm going to wrap the box with it. I found some good ideas on a boat blog of all places that described how to fix ice boxes on certain kind of boats I'll post the link case anyone else wants to geek out on this / as I did earlier today.
Errol Strummer
1959 Airflyte
Post by Errol Strummer on Aug 14, 2013 22:20:27 GMT -8
Post by mobiltec on Aug 16, 2013 15:07:45 GMT -8
I like it. I've seen Bob do this as well and he says it works great if you can just find solid block ice. If you have a big enough freezer you can make your own. Most of the block ice I see in the stores these days is just crushed ice pressed together and they don't last long at all. I don't think they make the cooler as cold either.
Errol Strummer
1959 Airflyte
Post by Errol Strummer on Aug 16, 2013 15:19:19 GMT -8
We will see how it works here it is all done. I inspected the door and it has 3/4" ply inside so this needs to be addresed as well. Thinking of just adding some insulation directly to the inside of door. Ill post a pic when I try it Tomorrow.
Post by mobiltec on Aug 16, 2013 15:28:02 GMT -8
We are working on twins. The one I just took in is exactly like yours. Same flooring and everything. And it is possible that another one may show up here exactly like these two. All 59s.
1958 Shasta "Penny"
1958 Shasta Airflyte 16
Post by 1958 Shasta "Penny" on Aug 16, 2013 15:35:04 GMT -8
I have that same exact flooring. It's a shame it will have to be taken out and replaced, just too many of them are ruined. I love the colors/pattern!
Post by cowcharge on Sept 1, 2013 9:16:12 GMT -8
If you have room, I would at least double the thickness...
Post by Hamlet on Sept 1, 2013 20:22:38 GMT -8
FiftyEightShasta - That flooring has such wonderful colors in it. Is there any way you could chip out the damaged tiles and replace them with a coordinating pattern? It'd be a truly random design, and that might look even cooler than the original.
