boholady
Post by boholady on Oct 9, 2015 17:51:04 GMT -8
I noticed that the caulking or sealant on the windows is very old. How do I remove it to replace? What is the best way to replace it?
Post by nccamper on Oct 9, 2015 19:31:24 GMT -8
Caulk and goop have never worked for me. Not long term. My vote, pull the windows out and use something like this: www.vintagetrailersupply.com/Butyl_Putty_Tape_p/vts-419.htmIt takes less than an hour a window. Disclaimer: If the wood around the window is rotted, it will open a can of worms. But they're worms you will deal with sooner or later. Sooner will be less pain in the end.
Post by Ten on Oct 10, 2015 5:45:54 GMT -8
I would love to see what you are seeing, and referring to as caulking. If the windows have been gone-around with caulk or silicone, it can be a pain to remove, but getting rid of it is the best alternative. Most...yeah, I'll say most (less committal and more scientific than saying "all" or "always") Most campers were built with a putty tape around all the openings; windows, doors, vents roof vents, j-rails, and cargo doors as well. Over time the tape dries and hardens and loses its "grip" on the aluminum of the siding and the framing. This will always cause leaks...unless it had been kept under cover for all those years. Lots of owners have been known to "cure" the leaks with caulking of some sort, mostly silicone (miracle-cure that it is perceived to be...), globbed on heavily around the exterior of the frames. Roof coating or tar is sometimes the go-to for the roof vents, which is another problem but based on the same premise. The one I am finishing with this year was under a shelter for several years of its life. That kept the water out, but it does not stop the seals from drying out and going through temperature-change cycles. For the best expected results, I removed everything, a little at a time, and cleaned all the old residue off from the frames and siding, and replaced the putty tape. Be advised there is a difference between "putty tape" and "butyl tape". The differences are described in several places, and you may want to research that aspect a little too.
Post by mobiltec on Oct 17, 2015 18:43:15 GMT -8
This stuff works great for removing silicone calking and it won't harm the paint. No razor blades needed. FOLLOW THE DIRECTIONS and WATCH THE VIDEO. www.silicone-remover.com/
