goshawks
Post by goshawks on Sept 27, 2015 10:59:19 GMT -8
We are looking for some type of material ( maybe waxed canvas) to use as an awning on our 49 Trotwood. Some type of material that says 'old hunting camp", as that is the theme of our trailer. Any advice on types and thicknesses, grommets, ropes etc?
Post by vikx on Sept 27, 2015 21:07:08 GMT -8
I'm not "up" on old type awnings, but watch the weight. Your trailer has an awning rail that's designed for so much material/weight. I'm thinking waxed canvas might be heavy? Why not look for an older color (tan, olive, etc) but newer material?
You might contact Marti of Marti's Awnings to get a pro's opinion.
goshawks
Post by goshawks on Sept 28, 2015 3:15:01 GMT -8
Thank you great idea.
Post by vintagebruce on Sept 28, 2015 7:54:28 GMT -8
Post by Hamlet on Sept 29, 2015 12:29:09 GMT -8
Do you camp in areas that consistently experience heavy rainfall and/or high winds? If the answer is no, then 500 denier will be just fine. If there are a lot of strong winds, the grommets will pull out more easily with 500 denier. !000 denier is a lot heavier, which could put undue strain on the awning rail. Most of us would take the awning down when it's windy anyway. 1000 denier is also a lot heavier. It is more resistant to things like being dragged against rocks or rubbed on trees, things that happen when you're backpacking. But even backpacks aren't usually made of nylon that heavy. Backcountry shorts/pants aren't usually made with 1000 denier both because of its weight, and also because it's fairly stiff. Lots of things to think about. Good luck!
goshawks
Post by goshawks on Sept 29, 2015 13:41:55 GMT -8
Thanks for your thoughts... Waxed canvas has stood the test of time and has been around over a 100 years. No it isn't the lightest material going, but then again I don't plan on towing the camper by the awning rail either. It's very rugged and at 10.10oz to the sq. yard I don't belief a 10'x10' will be very heavy either , thanks to you that have given input!
