backpackster
1969 Triple E Comfort 15'
Post by backpackster on Sept 16, 2015 16:35:39 GMT -8
Other then gutting my first job was to remove the rusting propane tank holder and install a new jack. I measured the A-frame jack hole at 2 1/4" and got a good deal on a bulldog 5000lb jack for $39. Unfortunately when I went to install it, I discovered the lower plate cut out was only 2". Apparently this was common in the good old days. Most were 2 or 1 7/8" OD on the lower plate! So either I return the now scratched up bulldog and special order an inferior Jack or make the hole bigger. I tried honing/reaming the bottom hole and it was sort of working but I was going through grinding discs too fast and would take forever. The solution was to use a hole saw. How do you use a hole saw without a drill to guide it. You cheat. I screwed a 2x4 to the Jack hole. Then drilled a 2 1/4" hole in the wood. I then used the wood hole as a guide to drill out the steel lower plate to 2 1/4". Drilling slowly with lots of oil, it was surprisingly quick. Now back to grinding and hacking!
Post by Ten on Sept 16, 2015 18:05:43 GMT -8
Nice safety chains too, by the way....This really is a common old problem...when modern meets vintage the holes don't always line up. Thank you for the tip! Someone else here was recently struggling with this very issue.
Post by vikx on Sept 16, 2015 22:49:09 GMT -8
Excellent tutorial! Thank you, Backpackster.
Post by mel on Sept 17, 2015 6:30:47 GMT -8
Wish you had posted this 2 weeks ago we just did ours and use a dremel and slowly grinded it out, it took quite a while and a lot of bits later lol Did you make your safety "chains"? would love to see how you did them
Post by rogerthedodger on Sept 17, 2015 15:42:57 GMT -8
Yes, I too would like to know how you made the safety cables. Roger
backpackster
Post by backpackster on Sept 17, 2015 20:12:10 GMT -8
Thats funny. I tried to grind it out also but after I used 2 grinding wheels I thought there had to be a better way. A for effort for getting it done!! Regarding the safety chains. I bought these chains on special for $12 here: www.princessauto.com/en/detail/2-pc-3-8-in-x-3-ft-trailer-safety-cables/A-p8103608eA unique Canadian kind of store. While I was putting on new rims and tires, my brother-in-law had drilled two holes and popped them on without me even noticing. It helps that he is a builder and an old boat trailer guy.
