theresa
Post by theresa on Jul 29, 2015 18:16:34 GMT -8
So I've got the skins off my trailer all the way around, and on the door side it appears that the panel that sits behind the wardrobe closet is a different color and grain than the others. Is it possible that they used a different plywood on that one panel knowing that it wouldn't be seen much other than inside the closet? Or is this a typical variation in color/grain of birch? I'll try to get a photo of it tomorrow. It's very perceptible in person; not sure it'll photograph well. Regardless, I think there's some merit in doing that to save a few bucks.
Post by Ten on Jul 29, 2015 18:47:54 GMT -8
My Airflyte is the same way...plywood in the rear of the wardrobe, hidden away, in a spot which didn't require the finish of the shellac. It seems matched to the cubbie behind the refrigerator cabinet.
And by the way, I believe that everybody that ever built campers used cheap paneling, an cheap everything else, anywhere they could.
Post by bucketheadmn on Jul 30, 2015 4:46:14 GMT -8
My '66 Airflyte is also the same way - though it is more like cheap paneling throughout. Inside the cost/wardrobe there is different plywood panelling. I assume it is because it is something that people do not see so it did not need a 'finished face' on it.
Post by bigbill on Jul 30, 2015 5:30:31 GMT -8
Shasta built a very low cost trailer by using every piece of material, they threw nothing away if it didn't match it was used in a place they felt didn't matter. Price was more of a sales factor than perfection.
Post by mobiltec on Aug 6, 2015 16:45:19 GMT -8
Many of the manufacturers did this. Shasta wasn't the only one trying to save on costs. Just as it is today, the business was very competitive. The main reason Shasta was so popular was because of the price of the trailers. They made and sold millions of them over the years. Nothing is different today. It's like any other business.
Post by Hamlet on Aug 6, 2015 17:58:26 GMT -8
I went back and looked at the pictures we took when we were doing the un-building. The paneling was a different color where it had been protected from light. It looks as though the paneling on the closet side wall was just two pieces, the part behind the closet door just wasn't finished the same way. I think they must have slapped the polyurethane on after they put the walls up, or maybe just being away from light for 50+ years changed it a little.
I also suspect that they didn't try to match grains at the factory, which we so often do when we do a restoration. They just pulled sheets of a big pile, and if they didn't use the whole sheet, they used the leftover someplace you wouldn't notice much. Wise, and it didn't affect the integrity of the whole. After all, these weren't luxury homes, they were travel trailers meant for use in campgrounds that were not nearly as nice as ones we have now.
theresa
Post by theresa on Aug 7, 2015 5:22:55 GMT -8
I went back and looked at the pictures we took when we were doing the un-building. The paneling was a different color where it had been protected from light. It looks as though the paneling on the closet side wall was just two pieces, the part behind the closet door just wasn't finished the same way. I think they must have slapped the polyurethane on after they put the walls up, or maybe just being away from light for 50+ years changed it a little. I also suspect that they didn't try to match grains at the factory, which we so often do when we do a restoration. They just pulled sheets of a big pile, and if they didn't use the whole sheet, they used the leftover someplace you wouldn't notice much. Wise, and it didn't affect the integrity of the whole. After all, these weren't luxury homes, they were travel trailers meant for use in campgrounds that were not nearly as nice as ones we have now. Hamlet, I'm made my observation from the outside of the trailer where none of the panels would have been exposed to daylight. The panel right beside the door, which would cover the distance behind the closet as well as fridge area is a much redder panel with a completely different grain. It is the only one like it on the whole trailer. Since mine has been painted inside I can't tell if it were shellacked at all inside.
Post by SusieQ on Aug 7, 2015 9:20:38 GMT -8
I went back and looked at the pictures we took when we were doing the un-building. The paneling was a different color where it had been protected from light. It looks as though the paneling on the closet side wall was just two pieces, the part behind the closet door just wasn't finished the same way. I think they must have slapped the polyurethane on after they put the walls up, or maybe just being away from light for 50+ years changed it a little. I also suspect that they didn't try to match grains at the factory, which we so often do when we do a restoration. They just pulled sheets of a big pile, and if they didn't use the whole sheet, they used the leftover someplace you wouldn't notice much. Wise, and it didn't affect the integrity of the whole. After all, these weren't luxury homes, they were travel trailers meant for use in campgrounds that were not nearly as nice as ones we have now. I discovered the same thing stripping, sanding and prepping the wood for stain. It is impossible to get it all perfectly uniform because of the exact things you described . I about lost my mind. Where the grain is very close together because of the cut if the wood, it is naturally darker and looks like a different wood. My cubbies look like they were made if different wood but they also have a different grain pattern. I think the reason Shasta used the opaque paint/ wash whatever on the ash was to make it Ll look uniform. My drawer doors are totally different from my cabinet and closet door. But they all looked alike with Shasta's finish.
Post by vikx on Aug 8, 2015 22:22:43 GMT -8
Yeaup...
