Post by vikx on Jul 31, 2015 21:24:25 GMT -8
So happy the Dip is not the culprit.
And glad your sleuthing is helping! I like OSI gutter seal because it is easy to smooth and doesn't take a lot... I'd try that on your Pittsburg? seam on the roof. (Why on Earth would a company not use a roof seam there??) The vent looks very well installed.
The Dicor around the vent usually does the trick. It is not for sealing existing leaks, but rather prevents them in the first place. Good stuff. Takes an entire tube for each roof vent. Round and round, til it's all gone. You might check to be sure it stuck to the roof metal. I've seen some cases where Dicor fails to adhere but not many. (installation when it's cold for instance)
Thoughts:
1. The putty tape at the stained area looks to have slipped. I wonder if pulling the vent and replacing the putty might help? 2. If you do decide to pull the vent, slipping some shims (1/4" or more) just under the metal might allow water to run away rather than in. 3. Proflex is sort of a last resort if leaks are not cured. It really does work but is not ascetically pleasing, tho it is paintable. I use it for very iffy areas to prevent surprises, especially on an old roof that's been previously coated. It's great for the seams.
You are going to solve this. Just takes time. Love the sprinkler idea! Hang in there.
Post by Ten on Aug 10, 2015 19:12:06 GMT -8
Time spent on the roof...ran the seam seals with the clear gutter seal. Finally getting to test it out tonight.... Hoping for good news in the morning.
stanley
still eager, not yet jaded!
Post by stanley on Aug 10, 2015 20:26:46 GMT -8
What's that wet stuff? Here in CA we don't see much of that.
Post by vikx on Aug 10, 2015 20:49:38 GMT -8
Fingers Crossed Ten!!
Post by Ten on Aug 11, 2015 18:31:37 GMT -8
That wet stuff lasted all night last night. We had a little flooding in the area but nothing to write home about, just the usual in the low-lying areas and a couple "flash-floods" in some parking lots and streets. It rained so hard that sometime before it was light, the noise of the rain on the tin roof of the camper outside the bedroom window woke me out of a dead sleep. I can not imagine what it will sound like inside the thing... The all-night rain proved the roof seams though. No leaks around the vents any more....yay. I was slapped back to reality by a small puddle on the kitchen counter though. It appeared to be dripping from the low end of the window frame inside. My first assumption would have been the window seal, but I am inclined to believe after further study, that I may be dealing with another seam leak, as there are two seams that course into the sides of the window opening (on either side). I hate the thought of re-removing the awning and the front window so I think I am going to try to treat the seams first and test that out next time it floods. In answer to the leaks in question, I proceeded to install the break-away switch for the brakes. That should stop it...maybe not from leaking, but I'll take what I can get today...
