engine2
Post by engine2 on Jun 10, 2015 9:20:49 GMT -8
I found these white metal straps in the rear of my 69 Lark while cutting the rotten wood out of the walls. Can anyone tell me what they are or what their purpose is? Thank you for your time, Terry
RinTin
Post by RinTin on Jun 10, 2015 9:57:40 GMT -8
Probably just for framing reinforcement. Common at door and window openings.
Post by Ten on Jun 10, 2015 11:56:10 GMT -8
Shasta used that same type setup in the rear top in the "toaster"-shaped campers in the later 60's. I believe the strapping was added to the wood frame to help the aluminum skin hold its shape going over the bend at the rear of the roof.
