davek
Post by davek on May 19, 2015 20:33:59 GMT -8
Does anyone have a source for a reasonably priced tubular rivet tool like this one www.arbortime.mountainminded.net/html/the_better_tonka_rivet_tool_-_.htmlI assume I could make one from a c-clamp and rivet dies from Hanson rivet. These are the rivets I need to replace I believe these are 3/16" tubular rivets? What lengthes should I order? I know I can use pop rivets but would prefer to use tubular rivets if possible. Thanks for any help Dave
Post by John Palmer on May 19, 2015 21:04:02 GMT -8
I don't see how that tool would do your job even if it were still available? It does not have enough reach.
Just use a common buck rivet, or if you don't have access to the proper rivet gun, use a pop rivet, but it must be steel, not aluminum because this is a high stress area. Buck rivets can easily be cut down to the proper length, so it's better to order long.
