winchesterette
1961 Shasta
Post by winchesterette on May 17, 2015 9:12:35 GMT -8
We wanted to run a water line straight from the spigot/hose to our camper/sink. We have no need for a fresh water holding tank because we only camp at places with water/facilities. Has anyone ever done this?
Post by Ten on May 17, 2015 10:26:11 GMT -8
In the Airflyte/16SC there should be two separate faucets...one which is a hand-pump for drawing off the holding tank, and the other a simple twist-faucet which should be run in directly from the outside. Check (if you haven't already) for a line that runs up through the floor directly beneath the sink cabinet or the dinette bench. In the event it is not there (removed, replaced, non-existent because of unknown construction methods), there certainly is no reason a line directly in could not be added fairly easily.
