thralldad
Howdy!
Apr 26, 2015 14:47:41 GMT -8
Post by thralldad on Apr 26, 2015 14:47:41 GMT -8
Howdy!
Apr 26, 2015 20:14:33 GMT -8
Post by nccamper on Apr 26, 2015 20:14:33 GMT -8
Welcome!
Your camper is new to me. Great name.
I look forward to more photos.
Howdy!
Apr 26, 2015 22:35:14 GMT -8
Post by vikx on Apr 26, 2015 22:35:14 GMT -8
Welcome Paul!
Howdy!
Apr 27, 2015 4:46:57 GMT -8
Post by vintagebruce on Apr 27, 2015 4:46:57 GMT -8
to VTT. You probably ran across this thread, but if not, and you scroll down you will see viewer comments that indicate your camper was made by Vacation Homes in Elkhart IN. There are comments from other Royal Highlander owners that give what might be stale e-mail addresses, but it could be a starting point. Cute smaller camper! www.everything-about-rving.com/can-you-tell-me-who-made-this-travel-trailer.html
thralldad
Post by thralldad on Apr 27, 2015 11:51:49 GMT -8
I saw that thread some time ago. Mine was sold by Carl's Campers in Michigan.Not a lot of info out there!
RJ
Howdy!
Apr 27, 2015 12:25:22 GMT -8
Post by RJ on Apr 27, 2015 12:25:22 GMT -8
Howdy and welcome!
Howdy!
Apr 27, 2015 15:49:28 GMT -8
Post by mobiltec on Apr 27, 2015 15:49:28 GMT -8
Wowzers that's different... Welcome to our world...
thralldad
Howdy!
Apr 28, 2015 18:51:13 GMT -8
Post by thralldad on Apr 28, 2015 18:51:13 GMT -8
snow shot.
thralldad
Howdy!
Apr 28, 2015 18:54:43 GMT -8
Post by thralldad on Apr 28, 2015 18:54:43 GMT -8
Reinforced floor framing and solid foam insulation.
Howdy!
Apr 28, 2015 21:50:45 GMT -8
Post by vikx on Apr 28, 2015 21:50:45 GMT -8
Looks warmer than it used to be...
thralldad
Post by thralldad on May 9, 2015 17:58:54 GMT -8
Wet weather has delayed working on the interior so I started working on the electrical. Tell me what you think. First time wiring a box.
Post by vikx on May 9, 2015 21:32:50 GMT -8
Electrical looks neat and clean, very nice! Be sure the inlet wires are 10ga. (looks like you did) Even if your trailer inlet is 15 amp, 10 to the box really helps. I often use a 15 amp inlet with 14ga to a nearby J box, then 10 to the box. Makes for an easy upgrade later.
People, take a look at Thralldad's work. Note the red jumper for the two lugs at the top. Black wire is incoming hot, jumper provides 110 power to both breaker bars. White supplies the neutral bar. ALWAYS isolated from the ground bar in a trailer.
Suggestion: Think I'm seeing the main ground from the inlet but not the trailer ground to the frame? Or vice versa? Every trailer needs a heavy gauge wire from the box to the frame (10 minimum, I like 8) and a ground from the inlet. Never can be too safe.
Thanks for posting this photo Thralldad.
thralldad
Howdy!
May 10, 2015 15:45:17 GMT -8
Post by thralldad on May 10, 2015 15:45:17 GMT -8
Good eye! 10 gauge in. I'm replacing a non grounded 15 plug with a single screw in fuse with a 70 amp rated box with a 20 amp for the AC, and 2 15 amps for light and plugs/fridge. I haven't run the ground yet but I'll make it 8 gauge. Thanks!
thralldad
Howdy!
May 17, 2015 14:37:20 GMT -8
Post by thralldad on May 17, 2015 14:37:20 GMT -8
It's been raining for a couple of weeks but I got a break today. I was able to build the rear frame. I'll build the front next weekend and hopefully move up to the ceiling! I will install the paneling prior to installation. Making progress!
