dochalpin
1962 Shasta Deluxe
Post by dochalpin on Apr 17, 2015 14:50:57 GMT -8
I started removing the paneling around the dinette... The outside metal came off on the bottom (curbside) and is now "torqued". If one area of the metal is pushed in, the other side pops out.
Also, the metal at the upper corners of the door, ripped.
I think (and hope) it was because the roof wasn't supported. I now have a metal pole in there, holding things up. Hopefully I didn't ruin things too badly.
What's everyone's opinion?
Post by SusieQ on Apr 17, 2015 15:17:09 GMT -8
dochalpin, were you removing the paneling from the inside? The only proper way to replace the paneling is from the outside. You have to remove the skins. It helps to understand how your trailer was built. The walls are built as a unit and the attached to the frame, the rafters are added and the panels are basically sandwiched between the floor, cabinets, closets and the rafters. The skins go on last. You have to reverse this process to take it apart, otherwise you are going to encounter problems.
Some people "gut" the trailer on the inside and try to remove and replace the panels but this method simply does not work.
If you have bent your skins, they are probably still salvageable but may show the dents. You need to remove your trim (j-rails, awning rail) and then remove the skins and then remove the framing in sections and take out one panel at a time and replace it, replace the framing and do the next.
Post by SusieQ on Apr 17, 2015 15:22:20 GMT -8
Post by vikx on Apr 17, 2015 21:20:09 GMT -8
I agree, remove the J rails, windows, doors and take the skins loose! Do not gut the interior. You will cause yourself a lot less worry and stress doing it right the first time.
Post by bigbill on Apr 18, 2015 6:24:55 GMT -8
In many cases the interior paneling is all that is left to support the roof because of frame rot so when you take it away the siding starts to bend. Get the ceiling properly supported at the proper level then remove siding, repair frame structure and go from there.
