elewayne
Post by elewayne on Apr 15, 2015 21:12:33 GMT -8
Hi guys, I'm starting work again on my trailer after two years, (the 1949 Silver Lodger), that I'm totally rebuilding. There is no existing wiring to copy or anything. Anyone know of any good information on wiring a trailer, like a step by step sort of thing? Trailer Wiring for dummys?? Do I need DC wiring to interior lights? Would all the lights be DC? and just wall plugs 110? what all do I need to plan wiring for, inside. I have all the running lights wired already. I know, a lot of questions, just to start with. I'm feeling slightly overwhelmed. Wayne
Post by ladywendolyn on Apr 15, 2015 21:38:57 GMT -8
This thread below has all the info including a great diagram..
Wiring thread
Post by vikx on Apr 15, 2015 22:18:33 GMT -8
I would start with a good 110 system. Two or three lights, and some outlets, placed in handy to reach areas. Lighting above the table and sink are always good, maybe one in the back bed area or? You will need a power inlet, a load center (breaker box) and appropriate sized wiring.
A 12 volt system comes in when you are boondocking. A deep cycle battery will power a water pump and a few lights for about 3 days. More, if you're miserly with the power. I usually add at least 2 lights, ceiling and table area. A cigar plug comes in handy to charge a phone or tablet. If you have a battery, an inexpensive battery maintainer will safely charge it while on shore power. (20 bucks at Wally World)
PM me for my email address if you need more information.
Post by John Palmer on Apr 16, 2015 7:49:12 GMT -8
Good information so far.
One thing that helps me is to mount all of your accessories first (light fixtures/plug receptacles/water pump/battery/110V circuit box/shore plug/etc., etc.). Then just wire the 110V system first (Romex is larger and stiffer) so the smaller wires of the 12V system are not in the way. If you only concentrate on one electrical system (12V or 110V), and only one circuit at a time "from power source, to accessory destination" you will find it easy to keep focused on what's next.
Post by ladywendolyn on Apr 17, 2015 7:46:48 GMT -8
Great advice! I'm listening too!
