mitchell
Post by mitchell on Apr 2, 2015 11:40:22 GMT -8
Icebox came with the trailer I'm restoring. Trailer is a 49 lil caesar. Does anyone recognize this? The construction looks a bit shabby so I'm wondering if it's original and whether or not there are seals available for it. Figured its a long shot, but anyone knew it would be here. Thanks again You guys rock!
Post by ladywendolyn on Apr 2, 2015 12:13:17 GMT -8
Post by John Palmer on Apr 2, 2015 18:15:33 GMT -8
I have used the Hehr back frame gasket that you will be using on your windows. Depending on the door lip, sometimes it will slip on, other times you can cut the lip off with a razor blade and contact cement the seal bulb to the door.
Post by vikx on Apr 2, 2015 20:31:03 GMT -8
I use regular weather seal for thre door. The bulb kind, usually white. Works great on ours.
