Post by nccamper on Mar 19, 2015 19:06:54 GMT -8
I like the shape. Are they all plywood? Impossible to work on without breaking it down to the frame?
Post by John Palmer on Mar 19, 2015 19:20:59 GMT -8
All that I have seen are plywood walls, they were built just like a tear drop, cheap as possible. There's no reason that you could not rebuild it with the common stick and tin type construction style.
Post by vikx on Mar 19, 2015 21:10:05 GMT -8
All Corvettes I've seen have ply walls, yup...
Post by nccamper on Mar 20, 2015 6:10:59 GMT -8
A shame about the plywood. I like the look of this one. Bidding was up to $255 last night.
Post by ladywendolyn on Mar 20, 2015 7:21:35 GMT -8
I love the shape!
Post by vintagebruce on Mar 20, 2015 9:34:27 GMT -8
How many Corvettes had the inset front window section? I thought the front was not inset, so this is fun to learn.
Post by nccamper on Mar 20, 2015 15:36:24 GMT -8
yas
'63 Shasta Airflyte
Post by yas on Mar 20, 2015 17:02:30 GMT -8
$1025, with 9 days to go.
No title.
I also like the shape and the inset window.
elewayne
Post by elewayne on Mar 26, 2015 16:06:21 GMT -8
My old 1949 trailer was build from the factory in just 1/2 inch plywood with battens at the joints for nailing the 4 panels, of each side, together. In my opinion, its a really crappy way to build anything. If you have to nail into the edges of a sheet of 1/2" plywood it will split, especially if water gets to it at any point. A lot of the nails in the corner joints of mine could be removed by hand, there was just nothing holding it together any longer. I rebuild using framing when I redid the whole box. My steel rolling frame was good, as were the aluminum skins and windows, everything else was trash. I had no trouble in Colorado getting a new title. Get a letter from the current owner stating everything he knows about ownership though. that may be helpful.
