risgett
A bad day camping is better than a good day at work.
69 Shasta Airflyte
Post by risgett on Mar 11, 2015 6:39:35 GMT -8
For the air conditioner, my uncle owns a HVAC business and also teaches HVAC at the college. We threw around some ideas and wound up with this. We made a drip pan with a primary drain, and a secondary drain in case the primary one ever clogged. For the fresh air, we made duct work and ran it thru the floor with wire grating to keep critters and such out. For the hot air, we ducted it out a vent that we installed in the rear cargo door. This setup gives us 100% efficiency. I used a 12,500btu, 110volt A/C with built in thermostat, UV light and remote. I then built the goucho bed back around it. Parked in the direct sun on a 98 degree day and high humidity it has no trouble keeping the camper cool.
risgett
69 Shasta Airflyte
Post by risgett on Mar 11, 2015 7:01:42 GMT -8
I unhooked the pressurized air hookup for the water tank and then put a self priming pump in-line right after the tank. This is a pic from when I had it temporarily hooked up for testing. I have since ran all new wire, neatly, with quick connects in case I ever have to replace it(It's hard to get to). I built a new shelf to go over the dinette. Then came wood putty, sanding, priming and painting. Then I put laminate hardwoods down. I have since put down quarter-round molding, did some touch-up sanding and painting, trimmed out around the a/c, hung the new cabinet doors(I'm not crazy about the way they came out, so I might build some more), installed some more new light fixtures, and some other odds and ends. I will try to get pictures from the last month posted sometime soon. Also, I removed the original 15amp service and installed a normal travel trailer 30amp service. I ran all new wire and a new breaker box with multiple circuits. I added some more outlets around the camper as there were only a couple originally. I also installed two new 12 volt lights. That about covers everything so far, although I'm sure I'm forgetting some stuff. I'm glad to be back on this project and hope to have it finished by the end of April. Wish me luck!
Post by bigbill on Mar 11, 2015 8:22:31 GMT -8
I like your A/C set up you have completely isolated the air required to operate the unit from the camper that you wish to cool. Many people draw the condenser intake air from inside the trailer causing a vacuum that pulls outside hot air into the trailer increasing the load. Your system is exactly what I have been preaching for a long time, it looks very professional well done.
Post by vikx on Mar 11, 2015 11:01:05 GMT -8
This is great! I admire the A/C install as well. Thank you for posting the photo story, trailer is looking great.
Post by nccamper on Mar 11, 2015 17:12:48 GMT -8
A 12,500btu A/C unit? If you leave it on overnight in July your food will get freezer burn! Thanks for the photos.
