stormin
Post by stormin on Feb 18, 2015 11:50:08 GMT -8
Hi there kind folks, I am new to this forum. I sumbled upon it while looking for info on my 33 ft. 1986 Glendale Glendette park model camper. I have it set up where I plan to build my retirement house. Sorry but I don't have any photo's handy. I live in Southern Ontario and the camper is 500 km Noth of where I currently live. I am trying to set myself up comfortably while I start to plan and prepare to build my retirement house where I will move live in about 5 or 6 years. I am looking for info on wireing as I am off the grid. It would be great to get schematics, but any info would help. I run my generator and everything works great also the 12 volt battery system works great. When the generator is truned off, the inverter kicks in and switches from 120 volts to 12 volts as it should. There are a few things that I am trying to figure out as I would like to install an off grid battery bank. 1. I have 6, 12 volt Uligy high rate series batteries. Would it be okay to just hook them up parallel to the 12 volt imput cables to the camper? Normally there would just be one car battery at these input cables. 2.The camper has a full size furnace that I haven't turned on yet. Would the furnace blower run on the 12 volts, or is it somehow wired seperatly? 3. THe intrior lights in the camper are not the usual slide switch autamotive lights, they look like ordinary household lights, are they 12 volt light bulbs, or 120 volt light bulbs? I went to a camper dealership and they told me that Glendale went out of buisness when the recession hit about 6 years ago. Does anyone know of any way that I can get technical information on the elecrtical system for this camper? Any help would be greatly appreciated Thanks Norm
Post by mobiltec on Feb 18, 2015 19:30:58 GMT -8
Norm your question should be in the electrical wiring section.
Post by vikx on Feb 18, 2015 22:40:32 GMT -8
Hi and Welcome Norm!
I will answer what I can. I'm assuming your Glendale is not a true "park" model, but rather an extra large travel trailer with holding tanks and RV bathroom fixtures. Park models tend to have 110 lighting, *real* bathrooms and appliances are not usually 12 volt. Correct me if I am wrong on your trailer. A battery system is another clue that points to an RV. Glendale made both types and possibly a combination of the two.
A park model furnace normally runs on 110. (it's a difference of which motor is installed for the blower) Suburban makes two models, one has a 12 volt motor, the other 110. The 12 volt motor tends to wear quicker than the 110, but otherwise the two models are very similar. When running the furnace, it does take a lot of power, either directly from the battery bank or thru the inverter. I recommend a more passive heater like a Wave; the operate without power. Even a safely installed wood stove would be very nice.
You should be able to tell what the lights are by reading the bulb. It's very unlikely that a trailer would come from the factory with incandescent style 12 volt bulbs. (look like a normal everyday bulb you might use in your house) I'm guessing the lights are 110. Our vintage trailers have both 110 lights and a 12 volt light or two, so it's possible Glendale had both as well.
If you connect your batteries in parallel, the voltage remains at 12 volts. Be sure to use extra heavy battery cables to support increased amp hours.
Hope this helps. I'll also move this to the electrical section for you.
stormin
Post by stormin on Feb 19, 2015 8:47:34 GMT -8
Hi Vikx and thank you very much for your input, sorry for posting in the wrong section.
From the info that you have given me it sounds like I may have a combination "park" "travel" model. I did pick it up from a park. It has no holding tanks. It had a propane hot water tank. It has a full size propane stove. The bathroom is a bit bigger than normal travel trailer size, but not really normal appartment size. The electrical panle has both 120 volt and 12 volt breakers. When I got the trailer, it didn't have battery cables, so I inspected the back of the electrical panel and found the red and black wires thet were never used. I spliced in a set of jumper cables and the 12 volt system worked great, switching back and forth from 12 to 120 volts depending if I had the generator going.
The trailer is 33 feet long and it has 2 tip-outs that run almost the full lenth of the trailer. The tip outs require a huge effort to set up. They have to be pulled out by hand requireing 3 strong men. it also involves flashing and taring. This is why I thought it is a park model. I think due to the over all interior floor space and the fact that I do have a battery bank with a lot of power, and good generators, I would like to give forced air an attempt at heating.
The trailer has a cathedral cieling with a small ceiling fan I would think that would be 120v. I checked 2 of the light bulbs and they were old. I couldn't make out the wrighting on them. I'm thinking everything works off the inverter at 120v. next time I go up, i'll take a tester with me to get a better idea. It would be great if I could find out how to get the wireing schematics, but this it doesn't seem possible.
I wish it was near by so I could post some pics, maybe in the spring. Thanks again for your input Norm
Post by vikx on Feb 19, 2015 11:00:16 GMT -8
No worries about "where" you post, Norm. That's part of my job, keeping things organized...
Sounds like your trailer is a Park model. The lack of holding tanks is one clue. Also, if the toilet has a tank on the back (as in a house) it was never used as an RV. Many of these types of trailers were built so that they could be either/or, tho I can NOT imagine trying to set up the tip outs very often! Refrigerators are usually 110 only in park models.
I'm guessing you have a converter rather than an inverter. (1986) The missing battery would have been back up if shore power failed. Works like a charm, the only way to tell the power is off is if the TV goes out. LOL. Inverters really weren't popular until the 90s and very expensive back in the day. One thing about converters is that they will overcharge your battery(s) on shore power. Since you will be off grid, that shouldn't be a concern. Solar panels may be a very good addition to keep your battery bank in tip top condition.
The system works like this:
The main power panel was usually a combo 110/12 volt/converter. One side supplied 110 power via a breaker box, the other 12 volts. The converter portion automatically uses shore power if available, then battery power when the trailer has no 110 supply. In other words, the converter uses or "converts" 110 to 12 volts when power is available and charges the battery. With the power off, the battery supplies power to all 12 volt units, 110 fixtures will not operate.
With a converter, your 110 system will only work when the generators are on.
If the trailer was upgraded to an inverter, 110 items will operate off the battery bank. With the large bank you are planning on, they should supply adequate power if used judiciously. There's not a lot of difference in electrical operation with an inverter, the exception being that your 110 system will work off grid. Anything with a 110 heating element or motor will drain the batteries. (appliances, fans, furnace motor, etc)
Almost all later model trailers have a built in 110 system, supplying some lights and electrical outlets, as well as a separate 12 volt system. Again, just guessing, but I'm thinking the furnace has a 12 volt motor so that it could operate when off grid.
Many modern RVs have only 12 volt lighting. The bulbs are an easy way to tell: they are much smaller than incandescent, and do not "screw" in.
To test the light fixtures, put a new 110 bulb in the socket. If it works, it's 110. And you're right, the ceiling fan is almost surely 110...
Please keep us informed. Your journey sounds fun and interesting.
stormin
Post by stormin on Feb 21, 2015 11:01:32 GMT -8
Once again, thank you very much for all the feed back. I'm glad that you pointed out the facts about converters and inverters. My battereis are very costly so now I know not to take a chance with what ever charging system is in the camper. I have some very good intelligent chargers, that I will run off my generator until I get my solar panels set up. The last people who owned the camper had swaped out the propane fridge and hot water tank to electric. I have since installed a new propane hot water tank and propane fridge. The toilet is a camper poilet, it doesn't have a tank in the back of it. Travel model? Park model? I'm starting to think maybe it was more designed to be set up permanently off grid on a property as I don't think it would be practicle at all as a travel, yet it's not really a park model. Not really sure what it was ment to be. When I go back up there I will try to see what the make and model of the electrical system is and maybe I can get more info from that.
Cheers, Norm
Post by vikx on Feb 21, 2015 22:34:13 GMT -8
Thanks for the info Norm.
If the toilet is an RV toilet, it will need a tank of some sort as they don't have enough water to flush a sewer hose. The tank is used until 3/4 full, then emptied, which thoroughly flushes things. If there is a grey water tank, that also cleans the hose. (we know there's no tanks on your trailer) I wonder if the toilet has it's own tank? Possibly just below the body?
Modern converters usually have "smart" chargers, so they are not detrimental to batteries. Take a look at what you have (guessing Magnitek or WFCO) and it may be possible to switch it out to a Progressive Dynamics unit which has the smart capability. Also, your intelligent chargers are fine. Just bypass the old charging system.
Good on ya for the propane appliances!
Very excited to see how all this comes together. Hope you have internet out in the sticks... Take some pics when you can.
stormin
Post by stormin on Feb 23, 2015 18:23:00 GMT -8
Hi Vikx
It's hard to tell if there is a holding tank. The whole underneeth of the trailer is well sealed with sheet metal. The previous trailer that I used... You could see the holding tanks.
I didn't know that it is a possibility to switch out the converter. Good to know. Thanks again.
I'll make sure to take some pics when I get there and I'll post it as soon as I get home.
Best rgards Norm
Post by vikx on Feb 23, 2015 22:22:09 GMT -8
Open the toilet flap and peer down with a flash light. You should be able to see the tank or daylight. (assuming the cap on the outlet is off) Also, if there's water, it is a tank. You could jump around a little to make it more visible. Another way to tell is to look at the outlets. There should be a 3" valve with a pull handle for the black tank. Also, if there's a grey tank, there will be a 1 1/2 valve (or 2") It tees into the 3" line just before the outlet. Look for black pipes, caps, that sort of thing. They will be hanging under the belly... (might be white but I doubt that) Here's a pretty good blurb showing photos of the pipes and valves, plus good info: www.rvdoctor.com/2001/01/recreation-vehicle-waste-management.htmlOn the converter, you can still use the original "box", with the 110 panel and fuse block. It's pretty easy to bypass the original guts and use the progressive, a matter of wiring. Depending on the box, you may be able to remove said guts and the Progressive will slip right in. Yeah.
stormin
Post by stormin on Feb 25, 2015 12:59:26 GMT -8
Great to know about the panel. I will have to look into it further in the spring.
As for the holding tank... I don't remember if there was a pull valve. I did how ever hook it up to the septic system that I had going with my old trailer, hooked up a hose to the well that I made " one hundred and 40 feet away from the septic". used two 12 volt surflo pumps, and it worked great. I am very lucky with my property. The water table is four feet below grade, and it is all sand. I dug a hole about seven feet down, I cut the bottem of a 45 gallan drum, put it in the hole, hooked the sewage pipe to it, put a vent in it, and it worked great all last year. Cheers Norm
