pam
Serro Scotty 69
Post by pam on Oct 31, 2014 5:00:19 GMT -8
Any suggestions for a heater to warm up my half finished/work in progress, vintage trailer during the winter? I still have the skin off and am waiting on my electrical. I have the interior walls up but nothing in the way of insulation on the other side. I have plenty of work I can do on the inside but I need to get the heat above our current Wisconsin temp of 27 degrees. I'd be happy with any temp over 50 degrees. I'm on my driveway with triple tarps to keep the moisture off. My little 1964 Wildcat is only 13' so I'm hopeful that those of you in similar circumstances will toss some suggestions my way. After weighing electric, propane and the various options within, I'm unsure. Thanks in advance!
Post by bigbill on Oct 31, 2014 6:49:18 GMT -8
In my opinion electric is best for the following reasons. In our part of the world it is much less expensive than propane. It is more convenient, no trips for propane. Also I believe safer. Now with that said you will need a couple of heaters most likely and the will need proper extension cords and need to be plugged into separate circuits.
