Post by mobiltec on Jul 16, 2015 17:21:30 GMT -8
Loving it. How did you finally get that black underlayment stuff up. You said the water and newspaper idea was not working. And was that stuff sort of papery stuff or was it hard as a rock glue? Cuz the newspaper and water trick only works on the papery stuff.
dsldriver
1966 Aljo Sportsman
Post by dsldriver on Jul 17, 2015 9:24:12 GMT -8
Thanks for sharing all your pictures, you are doing a fantastic job restoring your trailer! Your posts will be helpful when we get started on our '66 Aljo Sportsman!
Post by mobiltec on Jul 17, 2015 12:33:37 GMT -8
DSL I've never seen an Aljo that looks like that. But then again I'm more familiar with 50s models. Are you sure it's an Aljo?
kasiden
Post by kasiden on Jul 17, 2015 13:48:41 GMT -8
Loving it. How did you finally get that black underlayment stuff up. You said the water and newspaper idea was not working. And was that stuff sort of papery stuff or was it hard as a rock glue? Cuz the newspaper and water trick only works on the papery stuff. We ended up using a heat gun and a Oscillating Multi Tool with a flat square cutter. I think the stuff was more glue like than paper but it did have some fibers. We heated a section and then used the tool to scrape it up. It would have been easier to replace the entire floor.
kasiden
Post by kasiden on Jul 17, 2015 13:51:08 GMT -8
That is an interesting camper. I have never seen one like it. Mine is titled as a 1966 but I have seen many earlier Aljos that had blonde paneling. Post some interior pictures when you have a chance.
RinTin
Post by RinTin on Jul 17, 2015 15:29:47 GMT -8
We ended up using a heat gun and a Oscillating Multi Tool with a flat square cutter. I think the stuff was more glue like than paper but it did have some fibers. We heated a section and then used the tool to scrape it up. It would have been easier to replace the entire floor. This made me smile as it is exactly what I did early on in my Aloha. The countless hours I spent doing this were wasted as I eventually ended up replacing the entire plywood sub-floor. You are right, replacing the floor was much easier.
Post by mobiltec on Jul 17, 2015 16:13:20 GMT -8
Yep. That's pretty much the way I have dealt with the glue type substance before. Thanks...
dsldriver
1966 Aljo Sportsman
Post by dsldriver on Jul 17, 2015 17:48:05 GMT -8
We're pretty sure it's an Aljo!
dsldriver
1966 Aljo Sportsman
Post by dsldriver on Jul 17, 2015 17:50:31 GMT -8
Here are a couple interior shots.
dsldriver
1966 Aljo Sportsman
Post by dsldriver on Jul 17, 2015 17:52:05 GMT -8
Any more pictures will be posted under my original post in the welcome area.
Post by mobiltec on Jul 17, 2015 19:43:56 GMT -8
Wow! Never knew they made anything like that. Like I said I'm kinda stuck in the 50s but thought I had seen just about everything. Neat looking trailer.
kasiden
Post by kasiden on Jul 18, 2015 8:15:00 GMT -8
Any more pictures will be posted under my original post in the welcome area. I wonder why my Aljo had the darker wood? Left overs possibly! Thanks for posting these.
kasiden
Post by kasiden on Aug 25, 2015 9:58:11 GMT -8
A few more pieces installed.
RinTin
Post by RinTin on Aug 25, 2015 11:23:09 GMT -8
Looks gorgeous. I'm doing the same with my trailer now.
kasiden
Post by kasiden on Sept 21, 2015 9:28:30 GMT -8
Formica counter top samples from Wilsonart. Arrived in about 4 days.
