boandsusan
Post by boandsusan on Sept 22, 2013 19:40:24 GMT -8
Thought I would let you all know that my portable air conditioner worked perfectly. Camping in Nashville with 100 degree temps we keep the temp in the trailer at a cool 70 degrees. I vented it though the floor in the closet and would pull it out when using it. Not a perfect set up but I like the flexibility of not having to haul the air conditioner when doing Fall camping. Thanks for following up. What make and model portable ac do you have? I may try this method before I cut a hole in the 63`s skin.
Post by kirkadie on Sept 23, 2013 17:59:40 GMT -8
Makes sense to me to put it up high since cold air likes heading down. Cabinet it's attached to takes much of the weight so the wall structure doesn't mind?... could you include an outside pic, since the vent looks like it's pretty close to the J rail? Kirk
stillgotomx
1964 Chinook Tow-trailer 13'
Post by stillgotomx on May 9, 2019 7:03:56 GMT -8
Nice under the bed AC shots. Thank you for this....
aslmx
Post by aslmx on May 11, 2019 6:04:49 GMT -8
stillgotomx
Post by stillgotomx on May 14, 2019 6:54:06 GMT -8
Thanks--these give me what I need, It think. to PRESS AHEAD....mb
stillgotomx
Post by stillgotomx on May 14, 2019 6:58:04 GMT -8
Fantastic post! Thank you guys!
mb
Post by mobiltec on May 17, 2019 12:13:48 GMT -8
Your ankles will be nice and cool... Might want to consider a fantastic fan to suck the heat out of the upper portion of the camper. Here's how I did it in the 58 Deville. It requires cutting a hole in the skin and the installation of a vent door on the outside and I beefed up the framing on the inside of the closet. I have videos of all this.
stillgotomx
Post by stillgotomx on May 17, 2019 14:12:09 GMT -8
I like this, but then where will I put the microwave? Hmmm. I will look for your videos on the matter--thanks!
Post by mobiltec on May 17, 2019 14:59:56 GMT -8
I like this, but then where will I put the microwave? Hmmm. I will look for your videos on the matter--thanks! LOL... Leave the microwave at home... Or replace the oven with a microwave. I've seen people put the microwave IN the oven... No one ever uses the ovens in these little trailers anyhow... They are only used when you have a full stand up oven anyhow. The small ones are kinda dangerous to use.
