sll
Post by sll on Jul 8, 2013 12:38:39 GMT -8
I am just about done with the electrical wiring (I keep saying that as my list of projects grows longer....), but I am not sure how to hang the j-box above the sink. The original had a piece of plywood stapled to the framing and then the j-box went inside a hole cut in the plywood. It seems there has to be a better way to do this!
I thought about building a frame for the j-box using 1X, but then I have to drill a bunch of holes to run the 14/2.
I am interested in any ideas/solutions you all have.
Post by vikx on Jul 8, 2013 23:18:46 GMT -8
Use an "old work" box with the little wings. I glue a 1/4" backer inside the cabinet and cut the hole for the box with my Multimaster. Really sturdies things up when installing the box.
sll
Post by sll on Jul 9, 2013 5:29:54 GMT -8
Hmm, not sure we are talking about the same piece - or I am really lost! We have a light that hangs between the cabinets in the "kitchen" area (it attached to the ceiling). Wiring for the light above the bed ran into a small box above that light and branched off from that spot. Here is a very crude drawing of what I am thinking. The plywood has a hole cut out for the j-box and the light fixture would screw into the plywood (after the paneling is in). The support 1X pieces have been cut out so that plywood can be attached. The 1X is then attached to the ceiling supports at both ends. Does this make sense?
Post by vikx on Jul 9, 2013 22:49:38 GMT -8
Yes, I wasn't listening close enough. I thought the light was in the cabinet and needed a backer. Can you use the existing support or similar? Reason being, the ceiling is so narrow, not much room. The original box will probably fit there as well.
Your light fixture has some added room for connections in the base as well. Hope this helps.
sll
Post by sll on Jul 10, 2013 10:36:14 GMT -8
Here is what I ended up doing. The plywood is a bit rough, but it is what I had on the garage floor!
Post by vikx on Jul 10, 2013 22:17:25 GMT -8
Very good! I like! If possible, strip the wire covering a little further back (leave about 3/8 cover inside the box, it will make installing things much easier. Also take photos of all wiring you can. Comes in handy when you have to install a rack or whatever...
Post by 62shastacrazymom on Sept 2, 2013 8:40:39 GMT -8
Here is what I ended up doing. The plywood is a bit rough, but it is what I had on the garage floor! I have a similar question, but I am not doing the electrical, so bear with me. I want to put a vintage "pendant type" light, hanging down in that SAME location. (like one with the chandalier type look that hangs down with crystals, etc....a small one tho). Obviously, I cannot tow while this thing is hangin down, so my plan was to try and wire it so I can remove it before towing. Would I just put in a standard outlet to plug it in?
Post by 62shastacrazymom on Sept 2, 2013 8:43:11 GMT -8
Very good! I like! If possible, strip the wire covering a little further back (leave about 3/8 cover inside the box, it will make installing things much easier. Also take photos of all wiring you can. Comes in handy when you have to install a rack or whatever... Vikx I am having an issue in this same area. My trailer didn't come with anything here other than a "bulb"..haha. I am changing it to a vintage antique pendant light. I want to put a small one that hangs down from the ceiling. Problem is, obviously, I cannot just up and tow with this light hanging...so my thoughts were to put an outlet on the ceiling here and plug/unplug? Any suggestions?
Post by vikx on Sept 4, 2013 22:28:59 GMT -8
Yes, a plug-in would allow you to remove the light quickly for travel. There are even flat plugs available that won't show.
Post by mobiltec on Sept 5, 2013 18:29:07 GMT -8
Anyone ever heard of a pancake box? They are flush mounted and the light fixture fits right over them and has the same fasteners as a regular 3-0 box.
Post by vikx on Sept 5, 2013 21:51:11 GMT -8
Good point, Mobil.
I'm wondering if a "hook" and disconnect for the cord would work...
Post by cowcharge on Sept 6, 2013 7:28:54 GMT -8
I am changing it to a vintage antique pendant light. I want to put a small one that hangs down from the ceiling. GLAMPER ALERT!
Post by vikx on Sept 6, 2013 8:45:04 GMT -8
Yes, appropriate photos in our Glamping section would be excellent! LOL.
Post by 62shastacrazymom on Sept 16, 2013 9:57:26 GMT -8
I am changing it to a vintage antique pendant light. I want to put a small one that hangs down from the ceiling. GLAMPER ALERT! Is it glamping if the pendant light has a neon sign attached that says Pabst Blue Ribbon? Just curious........ And I will likely do the plug/unplug to safely transport whatever glamper light I can find at an antique store...lol....My theme is western, so maybe some Antlers with lights attached instead....actually that's not a bad idea....shoot the country girl is now coming out!!....back to glamping....yes Ill post pics whenever this sucker gets finished. The new goal is January 2014.
