yankiwi
now where does THIS screw go??
1957 Shasta 1400
Post by yankiwi on Sept 29, 2014 22:24:49 GMT -8
Hi folks, first thanks for all that contribute to this site - so much talent and knowledge and willingness to share out there in the community - us newbies really appreciate it. well, i won the argument - ok discussion - on whether we should pull up the old (original) cracked and smelly flooring in "Flo" our '57 Shasta 1400. so now i need to lay new flooring. thanks to Larry's videos on getting the black paper and glue up and the Kiwi's hard work, the sub-floor is pretty darn clean - but def has some wear and tear. i have reinforced from underneath but was thinking about laying some luan down to get a nice firm surface on top - since there are existing staple in seams that make Frankenstein look like he had bandaids! anyone have an opinion on laying luan down first or should we skip the expense/weight and just go over the old floor? we want to go with Armstrong vinyl sheet - we like Meledy - but i'm getting mixed info on how to install it. will .08 be thick enough not to have nails punch through? (or just regular camping in and out gouge it?) right now the front windows are out of Flo - so i was thinking i could cut one full sheet and bring it in through the window area - we don't want seams. any advise is appreciated. cheers in advance. tracy
Post by John Palmer on Sept 29, 2014 23:08:58 GMT -8
You need to "cut and tape" together a full sized template. My flooring dealer has some heavy black "tar paper like" material that he sells me for this purpose. Save this pattern and use it to protect your new floor, while you finish the trailer.
The sub floor has to be VERY SMOOTH, or any small bump, like a nail head will just pop right through. The material may seem to be thick, but everything will show through it in time. I have never used the Luan, but understand that some have had good luck using it. I just mix up some 3M "two part" body filler, commonly referred to as Bondo to fill any imperfections or cracks. Then just use a belt sander to smooth it off. I roll on some primer over the filler, mainly to help me see any imperfections that I might have missed.
I've tried it several ways, but here is what I do currently. Make a pattern. Tape the pattern to the flooring material in the driveway, and cut it out with a utility knife. Get two people, and carefully roll the material up and slide it into the trailer. Note, I usually do the flooring with one end still open. Lay the flooring, being VERY careful at any corner cuts, because they will tear. After the flooring is laid, I let it sit for a day to stretch, and trim any areas that are too tight. Then I roll the flooring back and glue the left side of the trailer up to one half of the isle. It's best to use about six or eight wood dowels, or pieces of EMT conduit. Lay them on the glued floor surface, then roll the flooring back as you remove the dowels. They keep the flooring from sticking to the glued floor. You will not get much room to move the flooring so every little bit helps. This is the same method to lay Formica sheeting. The only one piece floors I have done are the old style Marmoleum with the jute backing.
I try to never roll and unroll the material when it's cool or cold out, only when warm. Also, DO NOT let direct sun light hit the newly laid flooring after it's glued, or it will pucker up like a huge blister, don't ask how I know about BAD THINGS, LOL.
Post by universalexports on Sept 30, 2014 15:56:53 GMT -8
Do NOT use luan, it has voids in it and will smash down over time, you want 1/4 inch sub flooring, it is solid.
yankiwi
1957 Shasta 1400
Post by yankiwi on Sept 30, 2014 20:54:23 GMT -8
thanks folks, i really appreciate the info. i will probably order the vinyl sheeting this week - cheers. tracy
