curlycat
Post by curlycat on Jul 6, 2013 19:00:26 GMT -8
Do the eyebrows have butyl tape underneath them?
Post by universalexports on Jul 6, 2013 19:10:58 GMT -8
mine did. probably keeps the water out of the screw holes.
boandsusan
Post by boandsusan on Jul 6, 2013 21:02:29 GMT -8
Yes tape but putty tape
Post by vikx on Jul 6, 2013 22:00:43 GMT -8
I use RV putty tape behind the eyebrows. Butyl tends to ooze to much. (true butyl that is-the RV shop will tell you RV putty is butyl, but it is a mix)
curlycat
Post by curlycat on Jul 7, 2013 11:35:49 GMT -8
Are we suppose to be using putty tape when we reinstall the windows? We have both putty and butyl tape but didn't realize there was a difference other than width and thickness. For that reason we used the butyl tape. It has oozed out further once we cleaned the excess off.
Post by Nomad on Jul 7, 2013 12:39:36 GMT -8
Here's a little information about the three more common sealant tapes used on vintage trailers. Putty tape used on the older trailers is actually more of a caulking tape or cord-tape and light grayish in color. It is still available today for use for home plumbing and exterior weatherstripping. Although pliable when applied, it tends to harden some over time and has a weak adhesion compared to other sealant tapes. Butyl tape is very adhesive and maintains it's malleability over the coarse of it's life but tends to ooze in extreme heats. It is a gray tape on brown paper. This works well for sealing when used in cooler climates and/or marine use. Butyl-Putty (RV Putty) is the standard today for putty tape for travel trailers and RVs. It has the flexibility and strong adhesion qualities of the Butyl tape while maintaining body in extreme heat, as well as being trimmable, due to the putty. It is a light gray tape on white crinkled paper.
curlycat
Post by curlycat on Jul 7, 2013 15:41:38 GMT -8
Nomadic Me. are you saying either one is correct?
saphie113
Good Lord, I have NO idea what I'm doing.
Post by saphie113 on Jul 7, 2013 18:06:28 GMT -8
I'm reading it as the Butyl-Putty (RV Putty) is really the best and I have to say I SO appreciate Nomadic's post putting it all together AND with photos. Somehow it all just clicked.
Post by Nomad on Jul 7, 2013 19:09:01 GMT -8
Nomadic Me. are you saying either one is correct? Yes, all three are usable for sealing your windows. Just keep in mind the different abilities, or lack there of, that each tape has. Butyl Putty (RV putty) is likely the better in your case where you have higher temps. EDIT: Edited to add, RV putty is likely the better in any case for trailer sealant. - Malleable
- Trimmable
- Strong adhesion
- Maintains body in hotter climates
- Long seal life
Post by vikx on Jul 7, 2013 22:29:17 GMT -8
I use true butyl putty in odd areas: behind backframe gaskets (Hehr windows or cargo compartments) and sometimes door trim. That is if the door trim is not part of a door frame and needs to be sealed against the skin. Butyl must be used sparingly but is very good for a narrow thin seal.
I agree: RV putty tape is the way to seal most flanges. (windows, vents, etc)
gonekayaking
1956 Shasta 1500
Post by gonekayaking on Jul 8, 2013 8:28:42 GMT -8
I can attest that the butyl tape on paper backing oozes!!! I am constantly (2 yrs later) cleaning drips, and suspect that I will need to retape at some point. It's only on a few areas of my trailer, wish I'd known I would have used much less of it.
keri
Post by keri on Jul 8, 2013 10:57:30 GMT -8
So the butyl-putty is the way to go but it seems like that's often just called "putty tape". Is butyl-putty the kind that VTS sells? I think they just call it "putty tape". Mobiltec just says "putty tape" in his videos too but I'm assuming he is using the butyl-putty. So confusing!
boandsusan
Post by boandsusan on Jul 8, 2013 15:59:11 GMT -8
We also use butyl-putty (the grey). The brand I use, packages it as "Putty Tape"
curlycat
Post by curlycat on Jul 9, 2013 15:48:24 GMT -8
We are having a hard time finding putty tape in a store here in Los Angeles. We don't have time to mail order. The RV places around here only have butyl tape. Any ideas?
saphie113
Post by saphie113 on Jul 9, 2013 16:12:03 GMT -8
Amazon Prime!
