cheri
1967 Vanbrook Trunkback
Post by cheri on Aug 7, 2014 3:01:45 GMT -8
Hi All, I know that this is a busy time for everyone, but I need some opinions. I thought that I could live with the painted cupboard doors until winter, but I just can't. It's not that they look bad, the doors are in good shape, I just can't stop imagining them in birch. The frames look like fir to me and take on a reddish color when stripped and shellacked. The doors look like a lauan type plywood covered with a fake wood grain. There is no banding on the edges. Can replacement be as simple as cutting and shellacking 1/2 inch birch? I could try to use the iron on edge banding, but I'm wondering if your trailers with birch doors have this or not. My wood working skills are very limited, and I don't own a router, so simple would be better. Next question. The original table was gone when I got the table. I cut a temporary table out of 3/4 inch plywood, but it seems awful heavy. Would 1/2 inch work, or would it warp too badly. I'm thinking of using hardwood plywood, staining, coating with clear epoxy and banding with a metal edge. Applying laminate seems too tricky. Opinions on the best plywood?? Last question/opinion. I'm putting in the strips that cover the plywood joints on the ceiling and trim around the door. The only strips I can find are pine. Has anyone found a stain that will closely match the birch? (multiple coats of shellack aren't matching)
Post by nccamper on Aug 7, 2014 7:25:42 GMT -8
"Can replacement be as simple as cutting and shellacking 1/2 inch birch?" I have a 1962 Shasta and 1962 Forester. The smaller doors on the Forester (photo 1) have a framing about 1" thick with 1/8 birch attached. The Shasta is lighter weight. The larger door (photo 2) is a solid piece of 3/4" Ashe. Birch is easier to work with if you ask me. "I cut a temporary table out of 3/4 inch plywood, but it seems awful heavy. Would 1/2 inch work, or would it warp too badly. I'm thinking of using hardwood plywood, staining, coating with clear epoxy and banding with a metal edge. Applying laminate seems too tricky. Opinions on the best plywood??" My forester table is 1/2" plywood and it's the original table. No sign of warping yet;-) The Shasta is also the original table, 3/4" think and it weights a ton. Applying a formica top is not that hard. Check out the videos at www.cannedhamtrailers.com. His videos are the Youtube of Canned Ham. "I'm putting in the strips that cover the plywood joints on the ceiling and trim around the door. The only strips I can find are pine. Has anyone found a stain that will closely match the birch?" I'd get a panel of birch (maple or oak if birch isn't available) and cut strips. Then amber shellac. Pine will never look exactly like birch.
cheri
Post by cheri on Aug 7, 2014 8:16:02 GMT -8
Wow, thanks for the advice and especially for the photo. None of my doors have frames, but it doesn't look hard to make them. I have left over 1/8th inch plywood, so this might be a great option. Light weight is GOOD. I have some 1/4 inch I could use for the ceiling boards, but I'm not sure I can cut something that long so straight. Thanks so much
Post by nccamper on Aug 7, 2014 9:46:33 GMT -8
The beauty of cutting strips is if you mess one up, it's only inch of wood. Cutting them with a finer blade on a skill saw isn't hard, but even a jig saw would work with a finer blade.
yas
'63 Shasta Airflyte
Post by yas on Aug 7, 2014 10:21:49 GMT -8
Cutting trim strips: we found a friend with a table saw and a fine-toothed blade and cut straight strips from 1/8" birch plywood, using a fence. Heavy table: here's ours. Made a frame with 1x, routed a slot and dropped a 1/4" piece of plywood in. Quite light. We put Formica on the top - Formica is easy to work. The next one I make will probably be birch - less durable but will look nice. I'll probably make two for the Airflyte, one birch, one Formica. vintagetrailertalk.freeforums.net/thread/1621/trailer-today-ii?page=7&scrollTo=17295
cheri
Post by cheri on Aug 7, 2014 11:38:54 GMT -8
Thanks for sharing the link. Your table looks great! I saw your post just as I was leaving for the lumber store. Now I have to stop and think. I think that the 1x and 1/4 inch plywood might be less likely to warp than just a 1/2 inch slab. What size edge did you end up needing?
yas
'63 Shasta Airflyte
Post by yas on Aug 7, 2014 19:43:31 GMT -8
