gryffendorfen
1962 Shasta Airflyte
Post by gryffendorfen on Aug 6, 2014 4:27:37 GMT -8
Does anyone know how to remove this? I already removed the four screws on the perimeter, but it still wouldn't come off. I am thinking the inside dial around the spout is threaded onto the pipe, but my crescent wrench will not fit around it. Thanks!
Post by vikx on Aug 6, 2014 21:50:55 GMT -8
If you can get the outside piece off, the flange might come off. It is threaded and designed to attach a hose to drain the sink. If you have a large nut on the inside, a sink wrench (Lowes, HD) will work. Good Luck, never fun to be a pretzel inside a sink cabinet...
Post by mobiltec on Aug 7, 2014 7:11:37 GMT -8
That nut on the outside just unscrews... Get a crescent wrench big enough to get around that nut.
gryffendorfen
Post by gryffendorfen on Aug 10, 2014 7:12:48 GMT -8
Got it with the crescent wrench. Thanks vikx and mobiltec!
