varky
Post by varky on Jul 7, 2014 15:03:10 GMT -8
I recently purchased a vintage trailer. I've been trying to clean it up a bit and keep running into snags. I originally thought it was in decent condition when I bought it, but this being my first trailer, I didn't know what I was getting into. The previous owners had installed some plywood over the original flooring, glued VCT on top of that plywood and then had carpet tiles over the VCT. I removed all of these layers down to the original flooring thinking I would put in some new flooring. However when I pulled out the carpet, there were ants and ant eggs which I removed. Then when I took out the plywood, I found that parts of the plywood were actively wet and more ants and eggs were festering underneath. Once I was down to the bottom layer of what I think is the original floor, I found that most of the floor through the middle of the trailer was pretty soft. At this point, I'm not sure where to go next with this. The water is definitely concerning, I can't tell if it is a fresh leak or water that has been trapped between all these layers for a while. It was found mostly in front of the cabinets with the sink but there is no water tank in the trailer and I'm not sure if the sink has been actively used in months. I am also not sure what would be involved in repairing or replacing the original floor. Any advice would be greatly appreciated. This is the trailer (help identifying it would be great too): A couple pictures of the floor after I removed all the layers, it looks like one of the previous owners had tried to cut into it for some reason:
Post by SusieQ on Jul 7, 2014 17:40:55 GMT -8
Welcome to VTT! What a cute trailer. Sorry you were deceived. It really sounds like there is an active leak and that it has been trapping water for a while. You may be surprised at where the water is actually coming from. Are there other signs of water damage such as water marks around the vent? How about the baggage compartment? Have you checked underneath for rot and water damage? Check the four corners underneath. Use Mobiltec's icepick method and poke for soft spots. There is a thread here with suggestions for what to look for when buying a trailer. I know it sounds a little late, it will give you an idea of what you have.
What year and model is your trailer? We would love to see more pics of your interior!
Don't get discouraged, everything is repairable. It may take more time and money than you originally anticipated but many of us have been there and survived.
varky
Post by varky on Jul 7, 2014 21:20:33 GMT -8
I believe it is a 1967 Aladdin, but I'm not sure what the model is. Can you link to the thread with the icepick method of looking?
I briefly got under the trailer earlier today and it looked like it was in relatively good shape. The soft spots I can feel on the inside are mostly in the center of the trailer and not near the edges.
I replaced the roof vent last week and when I was up there, I didn't notice any of the plywood being particularly soft or wet, not nearly to the extent that the floor was.
I'm not sure how to go about figuring out if there is an active leak or if it was just trapped water.
Also, could someone elaborate on what the floors in these things are constructed out of? Is it possible to cut out a piece of the floor in the middle over the joists and just replace that with a new, non-rotted piece of material? Or would I need to disassemble the entire interior and replace the floor in its entirety?
colagirl
Post by colagirl on Jul 8, 2014 13:28:35 GMT -8
varky The floors in most of these trailers is 3/4 in plywood. Its pretty simple to cut out a bad spot by setting your saw blade the thickness of the floor,and cutting over the joist so you have something to nail to. Your only other choice is to take out every thing that sets on the floor and replace the floor. The good news is this possible because side walls do not sit on the floor , they screw to the side of the floor. Been there done that.
Post by SusieQ on Jul 8, 2014 16:40:27 GMT -8
Post by vikx on Jul 8, 2014 22:21:10 GMT -8
Beautiful little trailer. I've not seen the diamond pattern on an Aladdin before, so may be a closely related breed...
Post by mobiltec on Jul 13, 2014 17:36:12 GMT -8
All old trailers have one thing in common. They all need repairs from leaks and other types of damage. The ones that don't have been in a barn their entire life and that means you found yourself one heck of a nice deal. But those are few and far between. Welcome to the asylum....
Post by Teachndad on Jan 1, 2015 20:47:34 GMT -8
Hi Varky,
Please share what has happened in the last 6 months.
cheers,
