Post by SusieQ on Apr 27, 2015 15:50:25 GMT -8
It looks fabulous! Like new!
wolvenwood
Post by wolvenwood on Apr 28, 2015 7:00:52 GMT -8
Thanks for the encouragement. The skins are from Hemet Valley, and those guys totally rock. All the corners have Sik-a-flex under the overlap, and all the door, window and vent openings have Sik-a-flex between the wood and the aluminum. Water is really going to have to do some magic to get under this little lady's skin.
Post by mobiltec on Apr 28, 2015 14:16:07 GMT -8
Thanks for the encouragement. The skins are from Hemet Valley, and those guys totally rock. All the corners have Sik-a-flex under the overlap, and all the door, window and vent openings have Sik-a-flex between the wood and the aluminum. Water is really going to have to do some magic to get under this little lady's skin. Where did you get your sik-a-flex and which product did you use. I looked this stuff up to see what it was and they have many marine use sealants and adhesives. Very expensive I might add.
wolvenwood
Post by wolvenwood on Apr 29, 2015 18:18:54 GMT -8
I'm using the Sikaflex 221, polueurethane sealant. Kinda pricey, but I fixed a lot of leaks in a 29' Prowler with it, so I trust it. You can find it on the web for under $10 a tube. I think I got mine from Camping World, maybe. It's been a while.
Post by mobiltec on Apr 29, 2015 20:40:17 GMT -8
I'm using the Sikaflex 221, polueurethane sealant. Kinda pricey, but I fixed a lot of leaks in a 29' Prowler with it, so I trust it. You can find it on the web for under $10 a tube. I think I got mine from Camping World, maybe. It's been a while. OK that's the one I was looking at also. Thanks for the tip. I'll have to try that stuff...
wolvenwood
Post by wolvenwood on Apr 30, 2015 4:13:54 GMT -8
It's really sticky, and takes some umph to push out of the tube. Also, you'll need a solvent to clean up with. thinner or gasoline works fine.
Post by danrhodes on Apr 30, 2015 9:06:15 GMT -8
You can get some Sikaflex products at Home Depot. I know when doing my shower with kerdi waterproofing, Sikaflex caulking was about the only thing recommended other than the very expensive kerdi-fix brand. If it can waterproof a shower, it should do better than your average caulking in a trailer, as long as it's not the primary waterproofing method.
