annbclay
1961 Shasta Compact
Post by annbclay on May 30, 2014 15:03:13 GMT -8
In my past I used deep cycle marine batteries for running the fountain pumps in my art booth. I hooked 'em up to an inverter and they worked great, I only needed one good quality battery ($150) per 3 day show and kept them regularly charged when at home. problem is the suckers are HEAVY!
Now, I have my little Shasta compact and I'm setting her up to run the ceiling ventilation fan off of 12 volt when I'm not in a place with electric. I'd also like to use it to charge my Phone and iPad if possible. (I'll use battery powered LED puck lights and my propane lamp for lighting). I'm pushing the weight limit regarding my tow vehicle so I am working hard on minimizing every pound possible!
thus my question is: what is the smallest, lightest weight deep cycle battery I can get, which is sealed for indoor use and I can hook up to an inverter when I need to plug in my phone charger. I'd like to be able to get a few days out of it for the fan per trip before needing to charge it. Is that realistic without buying a huge and heavy golf cart battery?
Post by universalexports on May 30, 2014 15:27:52 GMT -8
annbclay
1961 Shasta Compact
Post by annbclay on May 30, 2014 16:06:04 GMT -8
I've been doing some reading and am now feeling overwhelmed with this decision! Maybe I should rephrase the question!
What type and size of battery would you (an experienced vintage camper owner) recommend for the purpose of running my small overhead ventilation fan at night for a few days at a time as well as occasionally attaching an inverter for plugging in my phone and iPad charger? Keeping in mind I am trying to minimize weight. Also I live in a very small house so will not store the battery in my house except when actively re-charging it or during the coldest months.
Post by John Palmer on May 30, 2014 18:28:08 GMT -8
First question have is why use an inverter? It complicates your battery issue, with little benefit. Just use a 12v car accessory plug mounted inside the trailer for charging.
"One" normal 12V deep cycle battery connected to a battery maintainer (like a Battery Tender JR.) is going to work just fine for your limited needs. Leave the battery stored inside the trailer, and it should be stored "plugged in" to the 110v system 24/7. The battery maintainers are "smart chargers" and shut off when the battery is fully charged.
annbclay
1961 Shasta Compact
Post by annbclay on May 30, 2014 18:41:33 GMT -8
First question have is why use an inverter? It complicates your battery issue, with little benefit. Just use a 12v car accessory plug mounted inside the trailer for charging. You know usually I'm pretty clever but that didn't even cross my mind! Thanks! also thanks for the other info. I do have a question however. I live in a little cottage with no garage so I'll need to run an outdoor utility extension cord to the camper for the charging. I won't want to keep that hooked up all the time. How frequently should I hook up for maybe a day of charging? Once a week? Once a month?
Post by John Palmer on May 30, 2014 18:59:33 GMT -8
First question have is why use an inverter? It complicates your battery issue, with little benefit. Just use a 12v car accessory plug mounted inside the trailer for charging. You know usually I'm pretty clever but that didn't even cross my mind! Thanks! also thanks for the other info. I do have a question however. I live in a little cottage with no garage so I'll need to run an outdoor utility extension cord to the camper for the charging. I won't want to keep that hooked up all the time. How frequently should I hook up for maybe a day of charging? Once a week? Once a month? Batteries loose voltage every day they are not charged. The rate they loose the voltage depends on temperature. When a battery has a low charge it sulfates the lead plates, and at some point it will not take a charge. If you keep it plugged into a battery maintainer they will last for many more years because of the "constant voltage level", and not having the big swing in discharge/charge which they do not like.
Based on my past life as a service manager in a motorcycle dealership we found that on ATV's, Jet Ski's, Utility vehicles, motorcycles, or any vehicle that is not used every day, the batteries go dead over time. You can buy a battery maintainer and "use it" as intended 24/7, or you can replace the battery every season. We sold over 3000 batteries per year at this dealership for new vehicles and service replacement. Batteries are "no longer cheap".
A 2.5MA Battery Tender JR. is a great product. But it's about $65.00 retail. I buy the same size "generic" battery maintainer at an electronics supply store for $38.00 and hard wire it into every trailer I build. You can then forget about it, just keep it plugged in.
annbclay
1961 Shasta Compact
Post by annbclay on May 31, 2014 7:47:42 GMT -8
Ok, thanks, I'll have to figure it out!
Post by cowcharge on Jun 20, 2014 2:04:29 GMT -8
I'm late to this thread, but in case you haven't bought your battery yet...
To accurately choose the "right" battery, you need to add up all your electrical usage per trip, in amp-hours, and buy a battery twice that size (because discharging a battery below 50% drastically reduces its lifespan). That's assuming there's no charging available during the trip, but if you have a charging source, then you can subtract the amount of charging amp-hours available from your usage amp-hours and buy a smaller battery.
To figure it out: Your fan has a data plate on it that tells you how many amps or watts it uses (if it says watts, just divide by 12 to get amps, because watts = amps x volts). Let's say it takes 4 amps (48 watts) like the fan in my furnace, and you want to run it for six hours per day. That means you have to come up with 24 amp-hours per day just for the fan. If that was the only electricity you'd ever use, you could buy a battery with a capacity of 48 amp-hours for every day with no charging. The very-commonly-used 75 amp-hour battery would give you a day and a half before it got down to 50%.
To be able to go camping confident that you won't have to, say, stop using the fan because the lights are more important and you can't power both, or worse, not noticing until the lights turn brown and the fan dies, you need to make a list of all electrical appliances, their amp draws, their projected usage hours per day, add it all up and double it to come up with the right size battery for one day's no-charging use. Six hours per day on a 2 amp light bulb would require another 24 amp-hours of battery capacity per day (6h x 2a x 2 [for the 50% discharge margin]). So the fan and one light bulb would require a 72 amp-hour battery for each day of usage without charging. It adds up fast. LED lights help a lot, but motors and heating elements will suck the power up.
All the batteries you're likely to consider are made mostly of lead, they all use the same chemistry, so they're all very close to the same weight for the same capacity. There just isn't a way to save useful amounts of weight without losing capacity, unless you add charging. For the record, sealed AGMs actually give you less capacity (and much higher prices) per pound, because the way they avoid gassing is to lower the charging voltage, and that means that they are never charged to the same level as a wet battery of the same weight (and which also makes them charge slower, and makes your choice of charger critical, both to prolong the life of your battery, and to prevent overcharging them to the point where you blow the gas safety valves, which ruins the battery instantly, if not causing an explosion or fire). The most efficient power-to-weight-to-dollar ratio comes from plain ol' wet lead-acid batteries, even though they are still heavy. No one's invented a styrofoam-acid battery yet.
It seems to me the best way for you to save weight would be to add charging, probably from the vehicle, since solar panels and generators also add weight. Make sure to use an isolator switch (of the proper amperage to match your alternator), which switches your alternator over to charging the camper battery after it's done charging the car battery (any auto parts store). If you just hook a wire from the car battery to the camper battery to charge them both at the same time, one will always be undercharged, unless they are identical batteries (and car batteries make lousy camper batteries). Also, make sure the charging wire is plenty big enough. A too-small wire of that length will waste a bunch of your charging power heating the wire instead of charging the battery, due to voltage drop. Good luck!
Post by John Palmer on Jun 20, 2014 8:35:21 GMT -8
LOL, I think we have overwhelmed the original poster with "sound electrical facts".
We might have "lost the patient on the operating table", but the surgery was successful!
